Md foam
Old   September 13, 2010, 15:16
Default Md foam
m.maneshi's Avatar
Mehdi
m.maneshi is on a distinguished road
Hi all
i have got two questions here on the mdFoam
1. will enough iterations lead the flow into a steady state situation in which no dramatic fluctuations with time are present ?
2. is the gravity for a pressure driven flow set through the Potential Dict Body force Gravity ? is it a non-dimensional parameter or not ?
Especial Thanks
m.maneshi is offline   Reply With Quote
Old   September 14, 2010, 20:23
m.maneshi's Avatar
Mehdi
and
3. Are averages calculated cell wise cell size dependent ? is so how can the proper size be found ? by trial and error ?
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
