Home > Forums > OpenFOAM Running, Solving & CFD
OpenFOAM 1.7.1: Oscillating CFL number
Old   September 15, 2010, 19:24
Default OpenFOAM 1.7.1: Oscillating CFL number
Lars Kiewidt
LarsPT is on a distinguished road
I want to simulate the capillary rise of a fluid in a closed rectangular container in a low-gravity environement using interFoam in OpenFOAM 1.7.1. So, I have only walls and symmetryPlanes as BCs. The container has a square cross section with length 1 cm and a height of 10 cm. The contact angle of the fluid is 0.
Here are the BCs (symmetryPlane is of course of type symmetryPlane):
alpha1:
walls
  type    constantAlphaContactAngle;
  theta0 0;
  limit    gradient;
  value  uniform 0;
p_rgh:
walls
  type    fixedFluxPressure;
  adjoint no;
U:
walls
  type    fixedValue;
  value  uniform (0 0 0);
My problem is, that the CFL number is kind of oscillating. So it increases up to 0.2 then makes a jump up to 8 or 10 and then it jumps back to 0.1 or even lower. After a while it crashes with sigfpe error. I already changed deltaT and maxDeltaT but it didn't help. The new capillaryRise tutorial doesn't work either. It shows the same phenomena and crashes with sigfpe error.
So is there someone else, who has had the same problems or who can help me?
Thanks in advance!
Lars
LarsPT is offline   Reply With Quote
Old   September 17, 2010, 02:07
ata
ata's Avatar
ata kamyabi
ata is on a distinguished road
Hi Lars
Did you examine your case with bigger contact angles?
Best regards
Good luck
Ata
ata is offline   Reply With Quote
Old   September 17, 2010, 09:40
Lars Kiewidt
Thanks for your answer.
No, I didn't, yet. But maybe it's a good idea. For now I tried to use a more viscous fluid to reduce the dynamics of the rise.
I read some papers about CFD (VOF) and contact angles. Is there any documentation how interFoam deals with the singularity of the no-slip BC?
Lars
Old   September 18, 2010, 01:50
ata
ata's Avatar
ata kamyabi
Hi Lars
How are you?
I hope you are doing very well.
What you mean "singularity of the no-slip BC"?
You can see the PhD thesis of Onno Ubbink entitled by:
"Numerical prediction of two fluid systems with sharp interfaces"
I hope that help you.
Best regards
Ata
Old   September 18, 2010, 03:55
Lars Kiewidt
So, I tried OpenFOAM-1.6 and it's performs stable but the results are not really good. 40 to 50 % error to the analytical comparison. I think, I have to work on the mesh and on the time step to get some higher accuracy. OpenFOAM-1.7.1 still crashes after a while. I don't think it's a bug, it is only because of the special case.
Now to the singulartiy and the no-slip condition. Usually the velocity at the wall should be zero but the fluid has to move anlong the wall in order to wet the surface. I read about an aproach of disabling the no-slip BC and replace it by a no-friction BC. The pressure loss is then compensated by an artificial body force. The intensity of the body force is unfortenatly a fit parameter and depends on the case.
By the way, I have the PhD thesis of Ubing and the one of Rusche, but I didn't get too much into it, yet. I think it will be worth doing so. Thank you for your help! But I still wonder why OF-1.7.1 has so many problems with this case while it is working with the former version!?
Lars
Thread Tools
Trackbacks are On
OpenFoam 1.7.1 in Ubuntu 10.04 won't start working Leech OpenFOAM Installation 8 August 10, 2014 20:42
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 6 April 17, 2010 23:40
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 05:56
how to calculate CFL number in 3D convection-diffusion channel flow dryhill Main CFD Forum 0 June 24, 2009 03:33
CFL number and time accuracy for LES Li Yang Main CFD Forum 2 August 1, 2002 06:11
