p_rgh in OF 1.7
Like Tree174Likes
Old   September 27, 2010, 04:57
Default p_rgh in OF 1.7
stawrogin is on a distinguished road
Dear Foamers,
I'm a little bit confused about the new pressure p_rgh in OpenFOAM. How is it defined? I worry a little bit the boundary conditions I have to define. For example if I would like to have a constant "pressure" at the outflow, how can this be defined ? If I define p_rgh = 0, does that mean that the pressure + (rho)*g*z is fixed to zero in this case?
Also I wonder why in some solvers I find a p-file and p_rgh file. Is the p-file only used for postprocessing or is it also possible to define boundary conditions there?
Thanks in advance.
Stawrogin
Luttappy, navidamin and Jun_93 like this.
stawrogin is offline   Reply With Quote
Old   September 27, 2010, 05:20
Juho Peltola
juho is on a distinguished road
In the 1.7.x buoyantPimpleFoam, both the p and p_rgh files are read. The p is used in the thermodynamic model.
In the createFields the p_rgh is defined as:
p_rgh = p - rho*gh;
So it is the pressure without the hydrostatic pressure and is intialized from the pressure field in the p-file.
In the pEqn.H file, the pressure equation is written and solved for the p_rgh, so the boundary conditions important for the pressure solution are the p_rgh conditions. After the pressure solution, the p is calculated with:
p = p_rgh + rho*gh;
juho is offline   Reply With Quote
Old   September 27, 2010, 05:27
Dear Juho,
thanks a lot for the help. Now it's clear for me.
Stawrogin
Old   September 30, 2010, 06:22
Nico T
deniggo is on a distinguished road
Hi Juho,
p_rgh seems to be the dynamic pressure. I work with pimpleFoam and pisoFoam. Is it possible to adjust these codes to obtain p_rgh?
Thanks,
Nico
deniggo is offline   Reply With Quote
Old   October 5, 2010, 17:52
Angela Wang
Angela Wang is on a distinguished road
Send a message via MSN to Angela Wang
Hi Nico,
Does p_rgh stand for the dynamic pressure, which means p_rgh=1/2*rho*U^2?
I checked the tutorial dam break case, why the value of p_rgh is greater than p? It implies that the rho*g*h is negative.
I am so confused.
Originally Posted by deniggo View Post
Hi Juho,
Thanks,
Nico
Angela Wang is offline   Reply With Quote
Old   October 5, 2010, 19:20
Kevin Maki
kjmaki is on a distinguished road
Hi Angela,
p_rgh is p - rho*g*h, or, the dynamic pressure. It was called pd in version 1.5, they solved for total pressure in version 1.6, and now are back to solving for only the dynamic pressure in version 1.7.
Kevin
kjmaki is offline   Reply With Quote
Old   October 6, 2010, 03:07
Nico T
Hi Kevin,
but why p_rgh is higher than p? How a negative static pressure (rho*g*h) is possible?
Shouldn’t 1/2*rho*U^2 (dynamic pressure def.) leads to p_rgh? Post-Calculation of U-field does not.
nico
Old   October 29, 2010, 15:19
Default Why p_rgh is greater than p
Nicolás Badano
nbadano is on a distinguished road
Dear fellows,
Oddly enough, gh is defined in openFoam as:
gh = g & mesh.C()
In other words, gh is the dot product of the g vector and the cell center position vector. As g is usually defined as (0 0 -9.81), gh often results negative in the positive z cuadrant!
Finally, as:
p_rgh = p - rho * gh
p_rgh is greater than p if z > 0
Hope this helps.
Best regards
Nicolas
nbadano is offline   Reply With Quote
Old   October 29, 2010, 15:26
Angela Wang
Thanks. My problem is solved. p_rgh is the dynamic pressure = p- rho*g*h
wayne14 likes this.
Old   November 17, 2010, 12:01
Logan Page
Logan Page is on a distinguished road
one more question regarding this:
Using the buoyantBoussinesqSimpleFoam solver, the units of p and p_rgh is (m^2)/(s^2) [i.e Kinematic Pressure]
obviously this is quite simply defined by: (p_rgh / rho) = (p / rho) - g*h
My questions is what density is used when dividing through. Is it rhok = 1 - beta (T - Tref) ??
Thnks
Logan Page is offline   Reply With Quote
Old   December 3, 2010, 12:20
abdikerim kurbanaliev
kerim is on a distinguished road
Hi fellows,
I'd like to continue Nico's idea. It seems to me that p_rgh is not dynamic pressure. I changed endtime to 500 in the laminar dambreak case. After that time initial transition flow will be stationary. So the there no dynamic pressure at t=500. But interfoam gives non zero p_rgh pressure. That is why I assume that p_rgh is not dynamic pressure. Could someone еxplaine me what is going on? Or am I wrong ?
Kerim
kerim is offline   Reply With Quote
Old   December 3, 2010, 13:29
Nicolás Badano
Hi Kerim,
p_rgh is not really dynamic pressure, specially in multiphase flow where rho changes throughout the domain. Is just de difference between real pressure and the rho*g*z field. I think that's one of the reasons the field is no longer called pd, as in 1.5 version of OF.
Just to add to the confusion, bear in mind thart rho*g*z is not the real hydrostatic pressure either!! Even if rho is constant it differes from hydrostastic component by a constant (the distance between the z=0 plane and the atmosphere p=0 plane times rho*g).
Here's a quick sketch of the relation between p_rgh, rgh and p for a hydrostatic condition (no movement at all). Hope this helps
Best regards!
Nico
paka, makaveli_lcf, verby and 49 others like this.
Old   December 13, 2010, 09:21
Default p and p_rgh files
  #13
Cristiano
Cristiano is on a distinguished road
Hello there,
I'm modelling a burner which has been tested at atmospheric condition and I'm a bit confused .
How can I do to set the boundary conditions properly for p and p_rgh?
Inlet -->
Outlet->
Wall--->
Thank you indeed.
Cristiano
Cristiano is offline   Reply With Quote
Old   January 14, 2011, 10:44
Illya Shevchuk
linch is on a distinguished road
@nbadano
I agree to your sketch: if the p-field is smooth, the h-field is also smooth, the g-field is uniform and there is a jump in the rho-field at h=h2, so the must be a jump in the p_rgh field. But if you set up your example in interFoam you'll notice, that the p_rgh field is uniform also. Though the p_rgh definition might be a littlte different.
Well, theoretically you'll get an uniform field, if you divide p_rgh by rho, but in this case you wouldn't get the p-dimension [kg*m^-1*s^-2]. So somehow the hydrostatic pressure is being substracted and not the simple product of rho*g*z.
Sorry, I was wrong about it. P_rgh is not uniform.
linch is offline   Reply With Quote
Old   February 10, 2011, 10:55
Default Tip
  #15
Christian Fri
christianfrias is on a distinguished road
Despite this a very simple suggestion it is worth to say it.
In case you have an OpenFOAM 1.6 case that had run successfully and want to run it in OpenFOAM 1.7 remember that you can just rename your p file to p_rgh (and also change some other parameters in your transportProperties and fvSchemes files). Then change the value of g from (0 0 -9.81) to (0 0 0). The case should work the same as in OpenFOAM 1.6 and you won't have to worry about if the BC that you are using in OpenFOAM 1.7 are ok if they were ok in OpenFOAM 1.6.
Cheers,
Christian F.
shizuka likes this.
christianfrias is offline   Reply With Quote
Old   May 17, 2011, 16:30
Default Bernoulli
  #16
Arnout
The King is on a distinguished road
To understand the different pressures, look at Bernoulli:
Dynamic pressure --> 1/2*rho*v^2
Hydraulic pressure--> rho*g*h
Static pressure --> p
1/2*rho*v^2 + rho*g*h + p = Constant
From the openFoam site, p_rgh = p - rho*g*h.
So, p_rgh is the static pressure minus the hydraulic pressure, based on a arbitrary height.
I do not understand where the dynamic pressure came into this discussion. I think it has nothing to do p_rgh. Dynamic pressure is the pressure of the moving fluid and it will convert into static pressure if you bring the velocity of the fluid to zero. Conservation of energy, back to Bernoulli.
Good to know:
To get my VOF model working, I placed in the fvSolutions file under the PISO solver
pRefPoint (0.0 0.0 0.0);
pRefValue 1e5;
Succes!
The King is offline   Reply With Quote
Old   June 24, 2011, 08:39
Nico T
thanks King, for the clearing explanation.
To finish the pressure confusion: The postprocessing utility "ptot" calculates the total pressure (static + dynamic) for every time step:
http://www.cfd-online.com/Forums/ope...lds-write.html
Cheers,
Nico
Mojtaba.a, Pirlu and mizzou like this.
Old   November 19, 2011, 05:52
Fernando Castro
fasfcastro is on a distinguished road
I think: P_rgh is the perturbation pressure (from an hydrostatic equilibrium state) that is actually used during the simulations in the momentum equations.
Harish Selvam likes this.
fasfcastro is offline   Reply With Quote
Old   November 29, 2011, 09:11
Howard NJOKU
Oke'e is on a distinguished road
why does p_rgh have units of m^2s^-2 in the bouyantBoussinesqPimpleFoam and the bouyantBoussinesqSimpleFoam examples, but has units of kgm^-1s^-2 under the (multiphase) interFoam examples?
Oke'e is offline   Reply With Quote
Old   November 29, 2011, 09:23
Andrea Ferrari
Andrea_85 is on a distinguished road
Because it is divided by the density in the first two cases. To have the "real" pressure" you have to multiply by density [kg/m^3].
best
andrea
Andrea_85 is offline   Reply With Quote
solver for subsonic compressible turbulent flow in OF 1.7 nileshjrane OpenFOAM Running, Solving & CFD 20 February 13, 2012 05:54
YPlusRas for InterFoam (Open Foam 1.7) MrD OpenFOAM 0 August 11, 2010 15:44
OpenFOAM 1.7 - openSUSE 11.3 - gcc 4.5.0 alberto OpenFOAM 12 July 28, 2010 11:59
MixSim 1.7 Tutorials johnnyb FLUENT 0 August 25, 2003 17:13
