wmake errors transportModels
Old   September 28, 2010, 06:23
Post wmake errors transportModels
T.D. is on a distinguished road
Hi i am trying to make a new viscosityModel in transportModels
i had two directories, main($WM_PROJECT_DIR) and user($WM_PROJECT_USER_DIR).
when i copy the src folder from the main to the user directory,
i do wmake libso incompressible from transportModels folder
it makes all .o files and at last i get this error:
mkdir: cannot create directory 'linuxGccDPOpt': permission denied
/bin/sh: cannot create linuxGccDPOpt/options: Directory nonexistent
make: ***[linuxGccDPOpt/options] Error 2
/opt/openFoam171/wmake/MakeFiles:39: linuxGccDPOpt/options: No such file or directory
make: *** No rule to make target 'linuxGccDPOpt/options'. Stop.
wmake error: file 'Make/linuxGccDPOpt/objectFiles' could not be created
- i tried also from the main directory where OpenFoam is installed from /opt/OpenFoam171/src/transportModels
to do wmake libso incompressible, but i get the same error
- when i try as sudo su (administrator) i also get that wmake: command not found
Help please
where really to copy new viscosity models, how to do wmake ????
thanks a lot
T.D.
T.D. is offline   Reply With Quote
Old   September 28, 2010, 06:37
Felix L.
FelixL is on a distinguished road
you can try to temporarily change the owner of the /opt/Openfoam171-folder:
sudo chown -R username /opt/Openfoam171 (where username is the name of the current user)
Compiling should be working then.
For safety reasons it's better to change the owner back to root afterwards:
sudo chown -R root /opt/Openfoam171
Hope this helps!
Greetings.
FelixL is offline   Reply With Quote
Old   September 28, 2010, 08:27
Smile Problem Solved
Hi
Thanks thanks so much, it really worked
i'm so glad, really thanks
I'll try to explain all the operation for others clearly:
Making a new viscosityModel
1-Copy the src folder from the main installed OpenFoam folder directory to your openfoam user directory.
2-copy the wanted law and change-rename it inside the /visocsityModels folder.
3-go to Make folder and add your new model directory to the existing ones
4-open console and type:
sudo chown -R username /opt/openfoam1xx
5-go back to /transportModels in the user directory of openfoam and open console and type:
wait till library is updated
6-change back to root by typing in a new console:
sudo chown -R root /opt/openfoam1xx
7-you can now run your applications normally with your new viscosityModel
T.D.
Problems Installing OF 1.6 32 bit bucksfan OpenFOAM Installation 19 August 4, 2009 01:36
OpenFOAM15 installables are incomplete problem with paraFoam tryingof OpenFOAM Bugs 17 December 7, 2008 04:41
Problem of compilation OF 14Allwmake command not found erik_d OpenFOAM Bugs 13 September 13, 2008 21:45
[OpenFOAM] ParaFoam error message joey ParaView 1 October 2, 2006 13:28
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
