Reversing Fan Direction / Cyclic Boundary Conditions
Hello
I'm using a cyclic boundary condition with a fan boundary condition by supplying the pressure rise curve but unfortunately the fan flow is in the wrong direction. How can I reverse the fan direction ? Thanks in advance |
Hi David,
Enjoy. mad |
Hi Mad
Thanks, I've seen that post but it refers to a model created using blockMesh. My mesh has been converted from a Fluent/Gambit file so I can't control the cyclic face master/slave in this way. I've tried a direct mesh conversion using fluent3DMeshToFoam with the cyclic defined as a fan and also converting a patch-a/patch-b pair and creating the cyclic using createPatch utility but no success. On a different model I got the right direction without any change so I think I am looking for a way to reverse the master/slave order. |
domain-1 domain-2 domain-3 domain-6 domain-7 and I want to make domain-6 cyclic. First I copy paste domain-6. A new domain is created: domain-4 (the first empty name on my domain list). As a consequence, domain-4 will be the master and domain-6 the slave. This works for my software (pointwise). Check if it is ok for Gambit as well. cheers mad. |
