trouble with Source Term
Old   October 1, 2010, 04:29
Default trouble with Source Term
andrianomena
sambatra is on a distinguished road
Hi there,
I would like to implement a Source Term.
The trouble is that it is calculated thanks to a lot of variables and the BC of that source term is not specified.I am a bit tempted to put a zerogradient everywhere when I implement it.Can anybody tell me what I should do?How can I specify the BC of that source term?
Best Regards.
sambatra is offline   Reply With Quote
Old   October 4, 2010, 03:22
Stefan Herbert
herbert is on a distinguished road
Hi sambatra,
why do you need BC's for a source term? The choice of BC's is only important, if you want to solve an equation for that field. If it is only a source in an equation for another field you can use the default calculated BC. (BTW the boundaryField shouldn't be used when having a volumetric source. In fact it should make no difference which kind of BC you use.)
Regards,
Stefan
herbert is offline   Reply With Quote
Old   October 5, 2010, 03:28
andrianomena
Hi Hebert,
Thank you so much for your information!
the reason I was asking that question was that the sources are to be relaxed so I guess creating field is required!
BR,
momentum source term zwdi FLUENT 14 June 27, 2017 15:40
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 13, 2000 23:03
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 03:43
