Home > Forums > OpenFOAM Running, Solving & CFD
Large case parallel efficiency
Like Tree22Likes
Old   March 16, 2011, 10:52
lakeat's Avatar
Daniel WEI (老魏)
lakeat is on a distinguished road
Send a message via Skype™ to lakeat
One more question concerning nCellsInCoarsestLevel, how to set it?
sqrt(mesh_in_total), or 10~30, or what?
Is SAMG much more better than GAMG? Any experience on that?
When will DICGaussSeidel be superior over GaussSeidel? Or there is even better options?
(Suppose this is an external incompressible flow with pisoFoam, have 10m grids pts, hex mesh).
Thanks
Daniel WEI
Boeing Research & Technology - China
Beijing, China
Email
lakeat is offline   Reply With Quote
Old   March 17, 2011, 10:40
Olivier
olivierG is on a distinguished road
hello,
You can have a look at this interesting thread.
The answer is to keep a small value here (10-20).
Olivier
olivierG is offline   Reply With Quote
Old   March 17, 2011, 10:48
lakeat's Avatar
Daniel WEI (老魏)
Since I have compared different nCellsInCoarsestLevel values both for a 5m grids case and also for a 10m grids case, I could not get any conclusion. For my 5m grids case, it seems 100 is better than setting it to 10~20, for 10m grids, case, I even find its good to set it around 3000.
That's why I feel kind of confused..
Daniel WEI
Beijing, China
Email
Old   March 18, 2011, 08:53
Arjun
arjun is on a distinguished road
Large number is usually (almost always) better.
Anyway, good thing from that thread is that I designed a new multigrid scheme that is very efficient. That exploits the fact that direct solver size affects the solution rate.
Previously Bi-conjugate gradient preconditioned by AMG was the best combination I have tried. Now the timings with new method are at least two times faster than previous best. Will be testing it against W and F cycles in coming days.
:-D
arjun is offline   Reply With Quote
Old   March 18, 2011, 09:39
lakeat's Avatar
Daniel WEI (老魏)
Why I found it is "not always", actually, too large a number will slow down the speed, so I feel confused, not knowing what is a optimized number.
Which one?
You mean GAMG?
I'd like to hear that, I have heard of this tech for quite a while, but not quite sure, how fast it is comparing with GAMG, so could you pls elaborate on this? Any experiences? Much appreciated.
Daniel WEI
Beijing, China
Email
Old   March 18, 2011, 09:49
lakeat's Avatar
Daniel WEI (老魏)
And also, It seems, scotch sometimes behaves better than metis... And I don;t know how to tune up the hierarchical method to find a optimized one, so I give up.
Daniel WEI
Beijing, China
Email
Old   March 18, 2011, 10:34
Arjun
too large size of direct solver would take more time. You said you tried 3000, for me 3000 takes lot of time, but this lot of time is relative. For 10mllion case, it may be negligible, while for a case with 10000 cells, it may be too much.
Which one?
Difficult to answer because since it is new one.
You mean GAMG?
In 2007, there was a paper by Jasak where he tried BiCG with AMG as preconditioner. (Or was it CG with AMG!!).
Anyway the crux was that the solver where AMG used W cycle was the fastest. Now if you look at W cycle, what it does is that it tries to solve problem at coarser levels to better convergence compared to V cycle. In case of direct solver, you do not iterate and solve the coarse problem to machine precision.
In both cases you are trying to essentially doing the same thing, that is to solve coarse problem to as high convergence level as possible without taking much time.
What I improved is to replace W cycle by some scheme more robust and better converging (on coarser levels), that takes similar or less time (but much higher convergence).
So far I am able to see speed up, but I have yet to make serious tests and comparisons. Specially with large sizes and W cycles.
PS: I am using my c++ library but the same scheme could be applied to any AMG scheme.
lakeat likes this.
Old   March 18, 2011, 10:38
Arjun
Not related to openFOAM but i wrote a small parallel data exchange code, that i am using. Good thing about it is that no matter what you use, its parallel efficiency do not go down. So far, at least my code there is no issue of partitioning. It is roughly 5 times faster than fluent :-D . (needless to say i am happy and relaxing :-D).
Old   March 18, 2011, 10:48
lakeat's Avatar
Daniel WEI (老魏)
Agree, this is exactly what I have observed, I just hope there would be a better way to quickly find this number, so we do not need to tune up over and over. Coz I think it is realated to cpu ability, RAM available, simulation complexity, and also just as what you said, "Is it relatively negligible". So this makes me confused, if some one would propose a better and faster method for this number. Pls correct me if i am wrong.
Interesting, when would you share your work to public.
And I also hope that the improvement is not just channel-flow friendly or box-turbulence friendly.
Thanks
Daniel WEI
Beijing, China
Email
Old   March 18, 2011, 10:58
lakeat's Avatar
Daniel WEI (老魏)
Originally Posted by flavio_galeazzo View Post
I normally allocate the nodes for simulation aiming for 1 second per time step, which is a good value in the system I work with.
Hmmmmm, serious question, because I have no luck to get this "1 second per time step" after having tried different combinations. So, my question is this, theoretically, what's the best efficiency that I can expect from parallel computing give a single type of cluster architecture.
For my case, I am not fully sure, but having tried different cpus, I found 4s/timeStep is the best I can get...
ANY "formula"?
Daniel WEI
Beijing, China
Email
Old   March 18, 2011, 10:59
lakeat's Avatar
Daniel WEI (老魏)
WoW, would you mind elaborate on this, lol
Daniel WEI
Beijing, China
Email
Old   March 18, 2011, 16:34
Arjun
Thanks
nothing special, replaced W cycle by another BiCG solver that again uses V cycle AMG as preconditioner. It solves to very high convergence levels (1e6 times) . So now it is as if direct solver size is say 1million cells or less. It is done on coarse enough levels , so that there is no penalty due to another BiCG routine. In a way it is a poly-BiCG-AMG solver. It is now roughly 2 times faster than normal BiCG AMG.
Old   March 18, 2011, 16:42
Arjun
I was writing an immersed boundary code (SIMPLE algo), so it is Local refinement type. I do not partition mesh by metis or any other tool. I have written the grid generation that writes meshes for each partition. This way one can handle meshes from say 100million to 2-3 billion cells.
(I added few things to fluent mesh format, if others also follow that we can have a universal mesh format for parallel calculations. Other things are information related to parallel interfaces.).
Anyway the trick to efficiency is that when data is exchanged, there shall be no collision. Means that if a process is sending data to another process, no other process shall be sending data to it. The program takes care of it. This is why, data exchange remains highly efficient no matter how i partition.
Old   April 7, 2011, 05:51
Eugene de Villiers
eugene is on a distinguished road
Hello all,
2. I am still not clear how you make Hierarchical a better option than metis. Are you aware of any general rules, or do you have any experience that it is super better than metis. If not, im gonna stay with metis.
Thanks
Daniel,
We have run some additional tests and found metis/scotch is in general better than hierarchical. Which is different than what we thought previously. Hierarchical can be better under very specific circumstances where the cell distribution is favourable, but for cases with highly non-homogeneous cell density metis/scotch has shown up to 20% better performance in some instances. The only problem for us at the moment is that our version of snappyHexMesh does not generally work with parMetis under 1.6 - we have not tried to debug this yet. I hope the parallel scotch in 1.8 will rectify this.
lakeat likes this.
eugene is offline   Reply With Quote
Old   April 7, 2011, 09:24
lakeat's Avatar
Daniel WEI (老魏)
Haha, I tried for many cases using hierarchical, and then I got an impression that it is too tricky to use hierarchical, so I gave up.
Btw, just curious, are you all able to make every time-step run within one physical second, even when you are doing some time-averaging operations?
Daniel WEI
Beijing, China
Email
Old   April 8, 2011, 03:14
Flavio Galeazzo
flavio_galeazzo is on a distinguished road
I like to use the "1 second rule" for my simulations, but I can't follow it every time due to the avaiable ressorces. But all my simulations have scale well up to now, even with time averaging turned on, and I am confident that all of them could run within one physical second per time step. Of course, the system arquitecture have to be adequate. With a machine using Infiband, I got good speed up (say more than 80%) for up to 256 processors in 64 nodes.
lakeat likes this.
flavio_galeazzo is offline   Reply With Quote
Old   May 17, 2011, 14:30
jdiorio is on a distinguished road
A (more basic) question:
Does anyone have a recommended method to determine if your system is performing optimally? I've run a simple case (3D cavity tut with 1M cells) repeatedly on a various number of processors (N=8,16,..,64) and I get very erratic results. The run times (even when using the same number of processors) can vary dramatically (>x4). The jobs are submitted through an LSF scheduler and I've tried a few things to test this issue, like submitting the job sequentially (e.g. 3 times in a row) on the same set of processors, or running three instances of the job simultaneously on three different sets of N-processors (if that makes sense). We added some code to Pstream to output the total amount of time each processor spent in MPI, and we find that MPI time can vary substantially across the cores, which we've been interpreting as some of the cores are running slower. However, this slow down isn't repeatable, and running the job on the same nodes doesn't reproduce the issue.
I apologize because my knowledge of MPI is essentially zero. Is this a hardware issue or a problem with how the cluster is constructed? Or is it some setting in MPI? I can provide more information about the details (cluster architecture, etc.) but wanted to describe the problem in general first. Running OF-1.6 using supplied openmpi-1.3.3. Any thoughts or avenues of investigation would be great.
jdiorio is offline   Reply With Quote
Old   May 17, 2011, 14:37
lakeat's Avatar
Daniel WEI (老魏)
Just want a double check,
1. What did you mean by saying "I get very erratic results", are you saying that the results each time are completely different?
2. Are there any other persons who is using your computing nodes or your memory, if so that would cause differences.
Daniel WEI
Beijing, China
Email
Old   May 17, 2011, 15:35
Thanks for the reply Daniel.
1. The results from the simulation (i.e. flow field) are the same every time. The run time (amount of time to do the same number of iterations) varies greatly.
2. Aware of this, and agreed that I can't really control for it. However, that's why I ran 3 jobs at the same time (i.e. same exact simulation, just on different nodes) because I figured these would be subject to the same network traffic at that time. Even these cases can be very different (~x2). Furthermore, I've gotten in the habit of checking the cluster load when I submit. I've submitted jobs when there's little to no load and they've taken much longer when network traffic was medium/high.
I'll add to that I've also tried looking at how the job is distributed (i.e. 8 cores on 1 node, 1 core on 8 different nodes, etc. Note: each node has 4 dual-core processors) and I don't see a definite pattern - that is, it's not like running a job with N=64 on 8 x 8 is better than some other distribution...
Old   May 18, 2011, 13:27
Flavio Galeazzo
Hi jdiorio,
If you cannot guarantee that the nodes work only for you, there is no surprise that your computation time varies greatly. One time the machine is working for your job only, and another time it is splitting the resources between X jobs.
If you are using the LSF scheduler, it is possible to reserve the nodes for your job only. Then your results will be consistent.
lakeat likes this.
Thread Tools
Trackbacks are On
Postprocessing large data sets in parallel evrikon OpenFOAM Post-Processing 28 June 28, 2016 03:43
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Parelleling Efficiency kassiotis OpenFOAM 0 June 19, 2009 14:12
Parallel efficiency channel flow maka OpenFOAM Running, Solving & CFD 1 December 8, 2005 13:58
Post-processing of a large transient case Flav CD-adapco 2 September 28, 2004 06:19
