-   -   simpleSRFfoam : request for volVectorField U (http://www.cfd-online.com/Forums/openfoam-solving/81202-simplesrffoam-request-volvectorfield-u.html)
jmf October 19, 2010 16:27
Hi everybody
I try to model a rotor in an open stream, using simpleSRFoam.
The solvers returns :
--> FOAM FATAL ERROR:
    request for volVectorField U from objectRegistry region0 failed
    available objects of type volVectorField are
1
Urel
    From function objectRegistry::lookupObject<Type>(const word&) const
    in file /home/nous/OpenFOAM/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 139.
In folder /0, there is a file Urel as follow :
internalField  uniform (10 0 0);
boundaryField
    inlet
        type            fixedValue;
        inletValue      uniform (10 0 0);
        relative        no;
        value          uniform (10 0 0);
    outlet
        type            freestream;
        freestreamValue uniform (10 0 0);
    rotor
        type            SRFVelocity;
        inletValue      uniform (0 0 0);
        relative        yes;
        value          uniform (0 0 0);
    cyclic
        type            cyclic;
In /system, fvSolution contains :
    Urel
        solver          PBiCG;
        preconditioner  DILU;
        tolerance      1e-05;
        relTol          0.1;
I'm sticked. Who might help me ?
Thanks in advance
Jean-Michel
jmf October 23, 2010 13:02
[solved] simpleSRFfoam : request for volVectorField U
Hello
My problem is solved : freeStream BC seems not to be compatible with simpleSRFFoam.
fixedValue fixed the error
Best wishes
Jean-Michel
be_inspired October 29, 2010 20:11
I have problems with SRFsimpleFoam. My mesh is 3D, it is a 120 sector with cyclic condition. Continuity errors are increasing at each iteration.
Could you share some information about bcs? Inlet, outlet, cyclic, wall and exterior fardfield?
Thanks in advance
WernerW July 28, 2015 15:16
5 Attachment(s)
i'm experiencing the same issue with the request for volVectorField U as JMF. I'm following your advice to change the boundary conditions where there is freestream (with an exterior flow) from SRFFreestream to fixedValue and to zeroGradient and it still doesn't work.
I think that the zeroGradient boundary condition is better since I don't have a wall in here. For the fixedValue BC's I should give the walls the same speed of the air, which must be very difficult.
I think I might have to mention the volVectorField U somewhere since I eventually would want to have such vector field as a result. Are you sure that the solution to this problem relies only in the definitions of the boundary conditions ?
I will attach the versions of the Urel that I have created. I have followed the SFRSimpleFoam/Mixer to set up the fvSolution and fvSchemes. I attach them here as well.
I would apreciate any help.
Regards,
Werner
