porousSimpleFoam - keyword wallDist undefined |
May 25, 2016, 09:20 |
Disabled
Rep Power: 9 |
Hi everyone,
I am working on a model with a porous net, which should be simulated using the porousSimpleFoam solver. When trying to run it, simulation stops shortly after having started and displays following error message: Code:
Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model kOmegaSST [3] [3] [3] --> FOAM FATAL IO ERROR: [3] keyword wallDist is undefined in dictionary "/home/nicolas/OpenFOAM/nicolas-3.0.1/run/sim_multipor_mapped_test1/processor3/system/fvSchemes" [3] [3] file: /home/nicolas/OpenFOAM/nicolas-3.0.1/run/sim_multipor_mapped_test1/processor3/system/fvSchemes at line 0. [3] [3] From function dictionary::subDict(const word& keyword) const [3] in file db/dictionary/dictionary.C at line 648. [3] FOAM parallel run exiting [3] Thanks in advance |
May 27, 2016, 04:27 |
This needs to be added to the end of fvSchemes. Code:
wallDist { method meshWave; } Code:
grep -r wallDist $FOAM_TUTORIALS Regards, Tom |
May 27, 2016, 09:46 |
Disabled
Rep Power: 9 |
It works, thanks a lot!
I was adapting a case made with v2.3.0 to work in v3.0.1, that's probably why this little detail slipped... |
January 4, 2017, 11:04 |
I am not 100% sure, but I believe the change was due to the method not being hardcoded anymore in the most recent versions of OpenFOAM. These kind of changes happen between major version changes and are usually described in release notes.
October 31, 2019, 06:42 |
neginmondegari
Rep Power: 6 |
Create time
Create mesh for time = 0 PIMPLE: No convergence criteria found PIMPLE: Operating solver in PISO mode Reading field p_rgh Reading field U Reading/calculating face flux field phi Reading transportProperties Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model kOmegaSST --> FOAM FATAL IO ERROR: keyword wallDist is undefined in dictionary "/home/negin/Desktop/article/article/system/fvSchemes" file: /home/negin/Desktop/article/article/system/fvSchemes from line 20 to line 55. From function const Foam::dictionary& Foam::dictionary::subDict(const Foam::word&) const in file db/dictionary/dictionary.C at line 701. FOAM exiting what does walldist mean and the best value for walldist is what? |
Second Derivative Zero - Boundary Condition | fu-ki-pa | OpenFOAM | 11 | March 27, 2021 04:28 |
LEMOS InflowGenerator | r_gordon | OpenFOAM Running, Solving & CFD | 103 | December 18, 2018 00:58 |
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 | Attesz | OpenFOAM Installation | 45 | January 13, 2012 12:38 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
G95 + CGNS | Bruno | Main CFD Forum | 1 | January 30, 2007 00:34 |
