Problem in Compiling the solver
Old   November 2, 2010, 07:44
Default Problem in Compiling the solver
m.maneshi's Avatar
Mehdi
m.maneshi is on a distinguished road
Dear all
Here i added one of the Header files to the solver files and compile it and i encounter this error which i cant understand it. would any one please help me what it does mean ?
In file included from mdFoam.C:67:
/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/temperatureEquilibration.H: In function ‘int main(int, char**)’:
/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/temperatureEquilibration.H:37: error: ‘targetTemperature’ was not declared in this scope
make: *** [Make/linuxGccDPOpt/mdFoam.o] Error 1
Regards
m.maneshi is offline   Reply With Quote
Old   November 2, 2010, 16:08
Default Options file in Make folder?
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
Did you set up your Options file in your make folder to include another header from a source outside your solver folder?
if I wanted to include something from the lagrangian basic and intermediate class, i would add the folder containing the header i wanted on the include path
EXE_INC = \
  ...other include files here\
    -I$(LIB_SRC)/lagrangian/basic/lnInclude \
    -I$(LIB_SRC)/lagrangian/intermediate/lnInclude
chegdan is offline   Reply With Quote
Old   November 2, 2010, 17:01
m.maneshi's Avatar
Mehdi
well, i didnt understand the point you mentioned completely. i do this by adding the # include <temperatureEquilibration.H> to the solver file and when trying to compile it such error happens... What is the reason for it?
Old   November 2, 2010, 17:41
Default that variable is undefined
Daniel P. Combest
try adding the header file readmdEquilibrationDict.H before the temperatureEquilibration.H file. The temperatureEquilibration.H file needs the variable targetTemperature to be defined...and that what it is complaining about. Im looking in the solver mdEquilibrationFoam in openfoam-1.5-dev...but this is probably relevant to other MD solvers in OF.
Dan
Old   November 3, 2010, 02:07
m.maneshi's Avatar
Mehdi
Thanks alot.
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
problem with developing new LES solver Edison_Ge OpenFOAM 2 June 18, 2009 01:26
CFX 11 x64 solver? problem Attesz CFX 6 June 7, 2009 08:37
Problem in compiling property(density) UDF satish2968 FLUENT 3 October 31, 2008 15:06
Problem in tesing the icoFoam solver liuzhw OpenFOAM Running, Solving & CFD 0 November 2, 2005 22:33
