simulation of mass transfer of liquid drop in openfoam |
November 11, 2010, 07:21 |
Salman
Besmellah,
Hi all, I want to simulate the mass transfer of an immiscible liquid rising drop in a column of organic solution. Is there any body who know which model of openfoam can I use to simulate the phenomenone? Regards Salman189 |
November 13, 2010, 07:08 |
mass transfer inside the drop
Salman
Besmellah,
Dear Nimasam, Sorry. There was a mistake in problem description. An organic drop rises in a solution of water+acid (20% acid dissolved in water) and absorb the acid inside. I want to simulate the mass transfer with open_foam. I am waiting your response. Regards, Salman |
November 13, 2010, 08:00 |
Nima Samkhaniani
Rep Power: 24 |
hi dear salman
look at solver description here : http://openfoam.com/features/standard-solvers.php however im not sure whether i understand you or not ? is ur model there phase or two phase? is it mixture or not ? is it immiscible or not ? as i know none of two phase flow solvers in multiphase flow solver consider phaseChange except interPhaseChangeFoam which is considering phase change based on cavitation but for solving a two immiscible liquids system u can use interFoam as a main solver and add ur mass transfer equations in it |
November 14, 2010, 05:48 |
ata kamyabi
Dear Salman
Hello I am in agree with Nimasam. You can use interFoam as a main solver and add your mass transfer equations in it. Good luck Ata |
August 15, 2011, 07:40 |
Hrushikesh Khadamkar
Hi Salman,
I am also trying to do the similar problem. In my case toluene drop is rising in stagnant water medium. How far did you manage to with your problem? Hrushi |
March 22, 2023, 13:34 |
Santhosh
Rep Power: 4 |
Hey there,
Have you guys managed to implement the mass transfer equations in InterFoam ? I am stuck with the same problem right now, if anybody could help me out that would be really nice ! Sincerely, Santhosh |
How to calculate Volumetric Mass transfer coefficient using CFX? | tuks_123 | CFX | 2 | July 22, 2010 01:15 |
Mass transfer Term in Mixture Energy Equation | CFDtoy | Main CFD Forum | 0 | July 3, 2008 16:14 |
free convective and diffusive mass transfer | rajani | FLUENT | 0 | July 27, 2005 08:28 |
Vof, udf and mass transfer panel | Jay | FLUENT | 1 | March 15, 2005 00:29 |
mass transfer from fluids to membrane | Peter | FLUENT | 0 | August 2, 2002 14:27 |
