mapping of pressure field (simplefoam to cavitatingFoam)
Old   February 14, 2011, 09:58
Smile mapping of pressure field (simplefoam to cavitatingFoam)
siddharameshwara is on a distinguished road
Hello to all,
I would like to map the pressure field of simpleFoam to cavitatingFoam. There is difference in pressue field of simpleFoam(it is in m2/s2 units) and cavitatingFoam( it is in kg/m/s2). There is difference between them by factor of density of fluid i am using. For that i have a file. I just found it in internet. Could any one tell me how to use it???
Thanks in advance.
siddharameshwara is offline   Reply With Quote
Old   February 15, 2011, 02:55
Matthias Voß
mvoss is on a distinguished road
how can anybody know what you found "in the internet".
What kind of packages/data do you get after unpacking the file?
mvoss is offline   Reply With Quote
Old   February 15, 2011, 03:05
Smile
I am new to this openFoam. So i didnt posted in a right way. It contains Make directory with 'files and options' files in it. and also convertPhi.C file. So i dont know how i can use it so that i can map(pressure field) from simpleFoam result to cavitatingFoam.
Or...is there any way to map the fields??
kindly suggest me.
Thanks
Old   February 15, 2011, 03:14
Matthias Voß
try to run wclean and a wmake in that directory. that will give you a library convertingPhi.lo which you can run from within your cavitatingFoam dir after maping your simpleFoam results.
Why don´t you just copy the 0/p-U-... files (convert them properly) from simpleFoam and run cavitatingFoam? But mapping is also fine....
neewbie
Old   February 15, 2011, 04:47
Smile
Thank you very much for the quick response. I tried the way you told me. I tried to make dynamic linking by typing the command wmake libso. It displayed the following message.
'libNULL.so' is up to date
So now if i want to use it how i can use???...how this could be used to map the results
i am sorry if this question is silly.
Thanks in advance..
Old   February 15, 2011, 04:49
Matthias Voß
why wmake libso?
Can you post a download?
Old   February 15, 2011, 05:07
Smile
When i looked in my documents i have found wmake libso would be best one. So, that it will have dynamic linking. I think it doesnt matter if it is static or dynamic link. Correct me if i am wrong!!
You can find in my attachments convertPhi.C file
I cant upload file and options. I have some problem.
In the Make--> file its written
convertPhi.C
EXE = $(FOAM_APPBIN)/convertPhi
and in make--> options its written
EXE_INC = \
-I$(LIB_SRC)/finiteVolume/lnInclude
EXE_LIBS = \
-lfiniteVolume
Old   February 15, 2011, 05:16
Matthias Voß
change
convertPhi.C
to
myconvertPhi.C
EXE = $(FOAM_USER_RAPPBIN)/myconvertPhi
change the .C file to myconvertPhi.C
wclean
wmake (not wmake libso)
run the tool in the copied file-structure of the simpleFoam run by typing
myconvertPhi
Make sure $FOAM_USER_APPBIN is set properly, check with
echo $FOAM_USER_APPBIN.
neewbie
Old   February 15, 2011, 05:39
Smile
myconvertPhi
I didnt understand the above statement.
Firstly, i will get the solution by typing the command simpleFoam in my directory where i am solving problem. So, when i have to type this command myconvertPhi after getting the solution of simpleFoam or what?? i cant type the command myconvertPhi and simpleFoam at a time.
Secondly should i copy the files that i have send you in the directory where i have ia m running simpleFoam
Thirdly, How after running the simulation i can map it.
Please clear this. i am sorry if i am roubling you.
Thnaks
Old   February 15, 2011, 05:52
Matthias Voß
1. compile the myconverPhi.C somewhere in a single folder by doing as stated above
if you succeed then you should be able to type "myco+[TAB]" and your system will auto-complete the rest for you; as the autofilling is working your system knows where to search for "myconvertPhi"($FOAM_USER_APPBIN) and the tool can at least be executed
2.create a case and run simpleFOAM
3.run myconvertPhi there after the simpleFOAM finished
4. map to your cavitatingFOAM directory
NO... see above 1.
(check out http://openfoamwiki.net/index.php/MapFields)
Old   February 15, 2011, 06:03
Smile
  #11
Thank you so much for the detail description. I will try it out the steps said by you.
Old   February 15, 2011, 08:21
Smile
  #12
I tried the steps said by you. But i am getting one error. I.e.
| \\ / O peration | Version: 1.6.x |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 1.6.x
Exec : myconvertPhi
Date : Feb 15 2011
Time : 14:12:37
Host : rbgv119x
PID : 4674
Case : /appl/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/fields/fvPatchFields/derived/myconvertPhi
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
--> FOAM FATAL ERROR:
Missing reference density
From function myconvertPhi
in file myconvertPhi.C at line 43.
FOAM exiting
So where should i give this reference density??. in my case for simpleFoam solver no where i mentioned the density. I mentioned only kinematic viscocity in constant/transportProperties. So where can i give reference velocity or is there any other way???...Fluid is desel.
Thanks inadvance.
Old   February 15, 2011, 08:46
Matthias Voß
first of all: it´s not good idea to put stuff in /appl/OpenFOAM/OpenFOAM-1.6.x/src/~ ... put your personal stuff beside the OF installation but that´s also a matter of taste.
rhoRef is a parameter for myconvertPhi
if (!args.options().found("rhoRef"))
        FatalErrorIn(args.executable())
            << "Missing reference density"
            << endl;
        FatalError.exit();
in myconvertPhi.C
argc=Number of Arguments
agrv=Argument
so try smth. like myconvertPhi 1000
1000 being your rhoRef.
Old   February 15, 2011, 08:56
Smile
  #14
Hey,
Thank you so much. It worked out. I looked at my rhop new file everything is fine the values and all......wow...thanks a lot for all your messages. Have a g8 day!!!
Old   February 15, 2011, 08:59
Matthias Voß
u r welcome...
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
About Pressure Field with Cyclic Boundary Conditio Jiaying Xu Siemens 2 October 4, 2001 09:11
Using SIMPLE david Main CFD Forum 5 July 21, 1999 02:38
