InterFoam (PimpleFoam) not obeying DeltaT in ControlDict |
February 28, 2018, 15:12 |
Shafik Walakaka
Rep Power: 8 |
Hi everyone,
I have set DeltaT in my ControlDict to 0.5 however the simulation is not using my updated DeltaT. What could be the possible case here? Could someone also please enlighten me what the MaxAlphaCo represents? (Is it important?) My logfile is given below (You can see that deltaT is not 0.5): ************************************ Courant Number mean: 0.302718 max: 1.41204 Interface Courant Number mean: 0.0231892 max: 0.990276 deltaT = 0.008971 Time = 24.4193 PIMPLE: iteration 1 smoothSolver: Solving for alpha.water, Initial residual = 0.000360174, Final residual = 1.52004e-09, No Iterations 3 Phase-1 volume fraction = 0.520186 Min(alpha.water) = -5.20278e-05 Max(alpha.water) = 1.01577 MULES: Correcting alpha.water MULES: Correcting alpha.water Phase-1 volume fraction = 0.520186 Min(alpha.water) = -0.000213347 Max(alpha.water) = 1.01577 DICPCG: Solving for p_rgh, Initial residual = 0.00755176, Final residual = 0.000356144, No Iterations 4 time step continuity errors : sum local = 3.02096e-05, global = -4.21979e-09, cumulative = 0.000897624 DICPCG: Solving for p_rgh, Initial residual = 0.000451891, Final residual = 1.72557e-05, No Iterations 18 time step continuity errors : sum local = 1.46355e-06, global = -1.61657e-09, cumulative = 0.000897622 PIMPLE: iteration 2 smoothSolver: Solving for alpha.water, Initial residual = 0.000276768, Final residual = 1.24055e-09, No Iterations 3 Phase-1 volume fraction = 0.520186 Min(alpha.water) = -5.20278e-05 Max(alpha.water) = 1.01577 MULES: Correcting alpha.water MULES: Correcting alpha.water Phase-1 volume fraction = 0.520186 Min(alpha.water) = -0.000201375 Max(alpha.water) = 1.01577 DICPCG: Solving for p_rgh, Initial residual = 0.000855169, Final residual = 4.08855e-05, No Iterations 6 time step continuity errors : sum local = 3.46725e-06, global = -1.14264e-09, cumulative = 0.000897621 DICPCG: Solving for p_rgh, Initial residual = 5.79757e-05, Final residual = 2.82631e-06, No Iterations 73 time step continuity errors : sum local = 2.39672e-07, global = -1.09359e-09, cumulative = 0.00089762 *************************************** My controlDict file is given below (Where DeltaT is set to 0.5): *************************************** FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application interFoam; startFrom latestTime; startTime 0; stopAt endTime; endTime 60; deltaT 0.5; writeControl adjustableRunTime; writeInterval 0.5; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression uncompressed; timeFormat general; timePrecision 6; runTimeModifiable yes; adjustTimeStep yes; maxCo 3; maxAlphaCo 1; maxDeltaT 1; ***************************************** Regards Shafik Last edited by walakaka; February 28, 2018 at 15:45. Reason: InterFoam, PimpleFoam, ControlDict, DeltaT, Courant |
March 1, 2018, 11:35 |
Rep Power: 11 |
you set adjustTimeStep to yes, so your maximum time step will be calculated based on your Co-number. If you want to run the simulation with a fixed time step just set adjustTimeStep to no. Best, Moritz |
March 1, 2018, 13:57 |
#3 | |
Shafik Walakaka
Rep Power: 8 |
Thank you for your reply! Could you also clarify the following for me please:
I appreciate your help! Kind regards Shafik |
Display Modes | |
InterFoam stops after deltaT goes to 1e14 | francesco_b | OpenFOAM Running, Solving & CFD | 9 | July 25, 2020 07:36 |
Unexpected deltaT decrease in pimpleFoam simulation | robyTKD | OpenFOAM Running, Solving & CFD | 9 | June 27, 2014 07:52 |
[HELP] deltaT decreases resulting in floating error, for interFoam | Zeallt | OpenFOAM | 3 | May 7, 2014 10:03 |
Problem with deltaT in interFoam | fedarduino | OpenFOAM Running, Solving & CFD | 0 | November 11, 2013 12:23 |
controlDict in interFOAM | amin66 | OpenFOAM Pre-Processing | 1 | July 10, 2012 12:08 |
