-   -   Help with chtMultiRegionFoam (http://www.cfd-online.com/Forums/openfoam-solving/83260-help-chtmultiregionfoam.html)
jbvw96 December 21, 2010 14:07
I am having trouble diagnosing the issue I am having getting CHTmultirgeion foam running. I have had a few of these Floating Point exception errors now and I have been able to find mistakes in the boundary conditions. But now I'm stuck, here is the output: where should I be looking?
| \\ / O peration | Version: 1.6.x |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 1.6.x-05e66c6c0080
Exec : chtMultiRegionFoam
Date : Dec 21 2010
Time : 08:04:48
Host : jbrodie
PID : 4193
Case : /home/jonathan/OpenFOAM/OpenFOAM-1.6.x/run/snappyShellTube
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create fluid mesh for region domain0 for time = 0.001
Create fluid mesh for region internal for time = 0.001
Create solid mesh for region tube for time = 0.001
*** Reading fluid mesh thermophysical properties for region domain0
Adding to thermoFluid
Selecting thermodynamics package hPsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>
Adding to rhoFluid
Adding to KFluid
Adding to UFluid
Adding to phiFluid
Adding to gFluid
Adding to turbulence
Selecting turbulence model type laminar
Adding to DpDtFluid
*** Reading fluid mesh thermophysical properties for region internal
Adding to rhoFluid
Adding to KFluid
Adding to UFluid
Adding to phiFluid
Adding to gFluid
Adding to DpDtFluid
*** Reading solid mesh thermophysical properties for region tube
Adding to rhos
Adding to cps
Adding to Ks
Adding to Ts
Region: domain0 Courant Number mean: 0 max: 129.5818
Region: internal Courant Number mean: 0 max: 111.2308
#0 Foam::error::printStack(Foam::Ostream&) in "/home/jonathan/OpenFOAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/jonathan/OpenFOAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted:
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/home/jonathan/OpenFOAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt/libOpenFOAM.so"
#4 void Foam::divide<Foam::fvsPatchField, Foam::surfaceMesh>(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/home/jonathan/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linuxGccDPOpt/chtMultiRegionFoam"
#5 Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > Foam::operator/<Foam::fvsPatchField, Foam::surfaceMesh>(Foam::tmp<Foam::GeometricField< double, Foam::fvsPatchField, Foam::surfaceMesh> > const&, Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > const&) in "/home/jonathan/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linuxGccDPOpt/chtMultiRegionFoam"
#6 Foam::solidRegionDiffNo(Foam::fvMesh const&, Foam::Time const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/home/jonathan/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linuxGccDPOpt/chtMultiRegionFoam"
#7 main in "/home/jonathan/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linuxGccDPOpt/chtMultiRegionFoam"
#8 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
#9 _start at /build/buildd/eglibc-2.10.1/csu/../sysdeps/i386/elf/start.S:122
Floating point exception
Thanks for any ideas you could contribute
Jean El-Hajal December 22, 2010 13:43
check time step
Hi Jonathan,
You probably have to check the Boundary Condition and/or the time step. The courant Number should be < 0.5.
The error massage say Courant number > 100 !
Hope this can help you.
Jean
Bufacchi December 26, 2010 18:16
Hi Jonathan,
It seems to me you have a problem in your region definition. I see a domain0 in you log file, which shouldn't exist. I understand your regions are internal and tube, so you should use ./Allclean in your case directory to clean it up and then make sure all files and directories reflect only these two regions. Delete all directories you may find in 0, constants and system directories.
Regards,
Paulo
