Lucas |
January 6, 2011 08:49 |
I tried this morning some changes in the fvschemes fvsolution
I also tried to run in simpleFoam
and i got this:
Time = 52
Lookup gradScheme for grad(U)
Lookup divScheme for div((nuEff*dev(grad(U).T())))
Lookup laplacianScheme for laplacian(nuEff,U)
Lookup fluxRequired for U
Lookup gradScheme for snGradCorr(U)
Lookup divScheme for div(phi,U)
Find relax for U
Lookup relaxationFactor for U
Lookup gradScheme for grad(p)
From function solution::solverDict(const word&)
in file matrices/solution/solution.C at line 241
Lookup solver for U
smoothSolver: Solving for Ux, Initial residual = 0.0237871, Final residual = 0.000128133, No Iterations 1
smoothSolver: Solving for Uy, Initial residual = 0.317853, Final residual = 0.00208853, No Iterations 1
smoothSolver: Solving for Uz, Initial residual = 8.9633e-05, Final residual = 4.39538e-07, No Iterations 1
Lookup interpolationScheme for interpolate(U)
--> FOAM FATAL ERROR:
Continuity error cannot be removed by adjusting the outflow.
Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow.
Total flux : 3.36963e+38
Specified mass inflow : 1.60459e+38
Specified mass outflow : 0
Adjustable mass outflow : 4.20186e+20
From function adjustPhi(surfaceScalarField& phi, const volVectorField& U,const volScalarField& p
in file cfdTools/general/adjustPhi/adjustPhi.C at line 115.
FOAM exiting
hear is my system files:
| \\ / O peration | Version: 1.7.1 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
application simpleFoam; // which solver (for documentation)
startFrom startTime; // firstTime, startTime, latestTime
startTime 0; // set > 0 to continue
stopAt endTime; // writeNow, endTime, nextWrite, ...
endTime 600; // Latest timestep allowed
deltaT 1; // simple counter for steadyState
writeControl adjustableRunTime; // or uncommon: cpuTime, clockTime
writeInterval 50; // time step write interval
purgeWrite 0; // 1 recycles time steps storage
// 0 keeps all time steps on disk
writeFormat ascii; // ascii: readable, binary: smaller
writePrecision 6; // precision for ascii format
writeCompression uncompressed; // compressed for gzipped files
timeFormat general; // fixed, scientific or general
timePrecision 6; // precision for time handling
runTimeModifiable yes; // yes: OF reads dictionaries each
// time step
graphFormat raw; // raw, gnuplot, xmgr, jplot
//libs() for user libraries, p.e. user boundary conditions
//functions() for special functions
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSchemes;
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
grad(p) faceLimited leastSquares 0 1;
grad(U) Gauss linear;
divSchemes
default none;
div(phi,U) Gauss upwind;
div(phi,nuTilda) Gauss linearUpwind Gauss linear;
div((nuEff*dev(grad(U).T()))) Gauss linear;
laplacianSchemes
default none;
laplacian(nuEff,U) Gauss linear limited 0.7;
laplacian((1|A(U)),p) Gauss linear limited 0.7;
laplacian(DnuTildaEff,nuTilda) Gauss linear corrected;
laplacian(1,p) Gauss linear corrected;
interpolationSchemes
default linear;
interpolate(U) linear;
snGradSchemes
default limited 0.7;
fluxRequired
default no;
p ;
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSolution;
solvers
p
solver GAMG;
tolerance 1e-07;
relTol 0.001;
smoother GaussSeidel;
nPreSweeps 1;
nPostSweeps 2;
cacheAgglomeration true;
nCellsInCoarsestLevel 500;
agglomerator faceAreaPair;
mergeLevels 1;
U
solver smoothSolver;
nSweeps 2;
tolerance 1e-08;
relTol 0.01;
nSweeps 1; // setting for smoothSolver
maxIter 100; // limitation of iterations number
nuTilda
nSweeps 2;
tolerance 1e-08;
relTol 0.1;
SIMPLE
nNonOrthogonalCorrectors 6;
convergence 1e-5;
pRefCell 0;
pRefValue 0;
relaxationFactors
default 0;
p 0.003;
U 0.007;
nuTilda 0.007;
