initial residual and final residual
Old   September 5, 2022, 05:19
Question initial residual and final residual
Sangho Ko
FluidKo is on a distinguished road
Hello everybody~!
I was wondering what is initial residual and final residual.
So I've searched these things in CFD Online and Youtube.
I've seen video at below link.
https://www.youtube.com/watch?v=OOILoJ1zuiw&t=1s
And I've found this post
SIMPLE: Difference between initial and final residuals
At upper link, 'Zbynek' has said that
"When your final residual is low enough, you update the matrix and repeat the whole process I just described (called outer iteration). Voila, you get a new initial residual that has naturally a larger value than the previous final residual."
I'm wondering two points.
1. Deos 'Ax=b' means Navier-Stokes equation?
https://youtu.be/OOILoJ1zuiw?t=281
At this link, MU=-\triangledown p is representing Navier-Stokes equation. So I've thought 'Ax=b' that Zbynek is referring is meaning Navier-Stokes equation and same to MU=-\triangledown p.
Is it right?
2. If 'Ax=b' means Navier-Stokes equation, then how A can be updated during outer iteration?
What I've guessed is below.
At below link,
https://youtu.be/OOILoJ1zuiw?t=360
MU=-\triangledown p can be transformed into Au-H=-\triangledown p.
And this means H=AU-MU can be expressed like below link.
https://youtu.be/OOILoJ1zuiw?t=410
Also H=AU-MU means H can be changed by U.
Because H is changed by U and H is component of MU, if U is updated M must be changed.
And M is same thing to A in 'Ax=b'
Is it right? I'm not sure...
Eventhough we've updated only x then substitute it into MU=-\triangledown p,
how M(same thing to A in 'Ax=b') can be updated?
Thank you~!
FluidKo is offline   Reply With Quote
pimple, residual, simple algorithm
laplacianFoam with source term Herwig OpenFOAM Running, Solving & CFD 17 November 19, 2019 13:47
Segmentation fault when using reactingFOAM for Fluids Tommy Floessner OpenFOAM Running, Solving & CFD 4 April 22, 2018 12:30
chtMultiRegionSimpleFoam turbulent case Aditya Patil OpenFOAM Running, Solving & CFD 6 April 24, 2017 22:13
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 02:20
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 06:37
