BC settings to expand pressure on atmosphere - simpleFoam / totalPressure
Old   February 8, 2010, 05:22
Default BC settings to expand pressure on atmosphere - simpleFoam / totalPressure
sErik is on a distinguished road
Hi Foamers,
I have a problem with the definition of boundary conditions.
I'm running a relativly easy case - standard backward facing step - with simpleFoam (kepsilon turbulence model) to compare the OF results with some other calculations.
At the inlet I have a velocity of 6,02 m/s and at the outlet I want the pressure to expand to normal atmospheric pressure (101325 Pa). My problem is, that I don't realy know, how to set the correct conditions for the inlet/outlet.
At the moment I have for U
inlet
type fixedValue;
value uniform (6.02 0 0);
outlet
type fixedValue;
value uniform (0 0 0);
wall
type fixedValue;
and for p
inlet
type zeroGradient;
outlet
{type fixedValue;
value uniform 0;
wall
type zeroGradient;
My boundarys are
inlet
type patch;
physicalType inlet;
outlet
type patch;
physicalType outlet;
With these settings, the simulation runs fine, but it's not exactly what I need.
I tried totalPressure with these settings - wall stays the same:
for p
inlet
type totalPressure;
p0 uniform 1.01325e+05;
U U;
phi phi;
rho none;
psi none;
gamma 1.4;
outlet
type totalPressure;
U U;
phi phi;
rho none;
psi none;
gamma 1.4;
for U
inlet
type fixedValue;
outlet
type zeroGradient;
But then the simulation crashes after a few steps:
Time = 0.4
DILUPBiCG: Solving for Ux, Initial residual = 0.4226, Final residual = 0.0131669, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.385886, Final residual = 0.00659647, No Iterations 1
GAMG: Solving for p, Initial residual = 0.993287, Final residual = 0.00404666, No Iterations 1
time step continuity errors : sum local = 14029.9, global = -1.97454, cumulative = -52.1146
DILUPBiCG: Solving for epsilon, Initial residual = 0.245904, Final residual = 0.00112502, No Iterations 1
bounding epsilon, min: -5.08864e+15 max: 2.93019e+16 average: 6.86567e+11
DILUPBiCG: Solving for k, Initial residual = 0.796412, Final residual = 0.0271624, No Iterations 1
bounding k, min: -7.85411e+07 max: 3.01688e+10 average: 2.10361e+06
ExecutionTime = 5.7 s ClockTime = 6 s
Time = 0.5
DILUPBiCG: Solving for Ux, Initial residual = 0.00899943, Final residual = 3.74612e-05, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.0728675, Final residual = 9.68172e-05, No Iterations 1
GAMG: Solving for p, Initial residual = 0.976204, Final residual = 0.00756845, No Iterations 5
time step continuity errors : sum local = 211598, global = 3456.42, cumulative = 3404.3
DILUPBiCG: Solving for epsilon, Initial residual = 2.35526e-05, Final residual = 3.37908e-07, No Iterations 1
bounding epsilon, min: -1.98511e+19 max: 4.34557e+20 average: 1.11602e+16
DILUPBiCG: Solving for k, Initial residual = 0.000959334, Final residual = 1.61051e-05, No Iterations 1
bounding k, min: -2.44986e+14 max: 9.10124e+14 average: 8.71869e+09
ExecutionTime = 6.37 s ClockTime = 7 s
Time = 0.6
DILUPBiCG: Solving for Ux, Initial residual = 0.587131, Final residual = 0.00365698, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.381925, Final residual = 0.0271016, No Iterations 1
GAMG: Solving for p, Initial residual = 1, Final residual = 0.0082871, No Iterations 7
time step continuity errors : sum local = 4.51584e+49, global = -1.07389e+49, cumulative = -1.07389e+49
DILUPBiCG: Solving for epsilon, Initial residual = 1, Final residual = 0.00710696, No Iterations 1
bounding epsilon, min: -7.62782e+71 max: 8.5466e+73 average: 1.90599e+69
DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 0.00716964, No Iterations 1
bounding k, min: -6.71536e+58 max: 3.06377e+59 average: 1.93931e+55
ExecutionTime = 7.11 s ClockTime = 8 s
Time = 0.7
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 0.00874036, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 0.00873079, No Iterations 1
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/opt/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 ?? in "/lib/libc.so.6"
#3 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#4 Foam::GAMGSolver::solveCoarsestLevel(Foam::Field<d ouble>&, Foam::Field<double> const&) const in "/opt/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#5 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/opt/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#6 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so"
#8 main in "/opt/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/simpleFoam"
#9 __libc_start_main in "/lib/libc.so.6"
#10 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116
It's clear, that bounding k and epsilon diverge, but I don't understand why. With the first settings, I get fine results.
How do I have to specify the correct BC for the velocity/pressure for my case?
I would realy appreciate your help!
Regards,
Erik
€dit
This is my k-file
inlet
type fixedValue;
value uniform 0.0748;
outlet
type zeroGradient;
wall
type kqRWallFunction;
This is epsilon
inlet
type fixedValue;
value uniform 0.960;
outlet
type zeroGradient;
wall
type epsilonWallFunction;
sErik is offline   Reply With Quote
Old   June 15, 2011, 02:49
Question simpleFoam totalpressure vof
hamdi
hamcer is on a distinguished road
Hello Foamers,
I'm doing a test case on an injector using simplefoam, and I am a bit stuck on the implementation of boundary condition on the pressure (how to use the totalpressure).
when I look at the velocity profile they are not the same as in vof. The jet is horizontal in vof, and isn't in simplefoam
Can someone help me, it's crucial for my thesis.
Thank in advance.
hamcer is offline   Reply With Quote
Laminar simpleFoam and inviscid simpleFoam herenger OpenFOAM Running, Solving & CFD 7 July 11, 2013 06:27
SimpleFoam TotalPressure loss prapanj OpenFOAM Running, Solving & CFD 1 July 30, 2009 11:09
