Home > Forums > OpenFOAM Running, Solving & CFD
How to get the real pressure if I need it
Old   March 7, 2011, 13:58
Default How to get the real pressure if I need it
lakeat's Avatar
Daniel WEI (老魏)
lakeat is on a distinguished road
Send a message via Skype™ to lakeat
I know its a stupid question, sorry to bring it up again.
But in a very simple case like icoFoam/cavity, when I doubled the mesh from 20*20*1 to 40*40*1, the pressure field doubled too, both the max positive pressure and max negative pressure. (See the attachments)
If so, im quite confused, then how could I calculate the real pressure? If I really need it.
Thanks
Daniel WEI
Boeing Research & Technology - China
Beijing, China
Email
lakeat is offline   Reply With Quote
Old   March 7, 2011, 21:08
lin
Hua Zen
lin is on a distinguished road
The different values of max pressure are because they are at different locations. The corner is a region with high pressure gradient, the finer resolution grid you use, the first cell closer to the corner, the higher max value you would get.
lin is offline   Reply With Quote
Old   March 7, 2011, 21:20
lakeat's Avatar
Daniel WEI (老魏)
oops, i see.. I use a threshold to replot the finer mesh case, and there's slight difference, but that is reasonable. Thanks for the hints.
Daniel WEI
Beijing, China
Email
Old   March 7, 2011, 23:01
Default How fine the mesh should be?
lakeat's Avatar
Daniel WEI (老魏)
I am more confused now, after refining the mesh, the forceCoeff (CD, CL, CM) of the movingwall of the cavity keeps changing with the refinements, im not sure whether there is a convergent point.
mesh              time       CD                 CL                   CM
20*20*1    :    0.5       -0.0250095       0.00127490       0.0307956
40*40*1    :    0.5       -0.0309481       0.00131934       0.0384033
80*80*1    :    0.5       -0.0368673       0.00135175       0.0460686
120*120*1 :    0.5       -0.0403592       0.00136456       0.0506198
240*240*1 :    0.5       -0.0462832       0.00137827       0.0583678
So, the questions are these,
  1. how fine the mesh should be, that I can have a reliable forceCoeff?
  2. Is this bcoz this is a laminar case? What will happen in a turbulence case.
Is this because singularities in the corners?
Daniel WEI
Beijing, China
Email
Old   March 10, 2011, 16:18
lakeat's Avatar
Daniel WEI (老魏)
To calculate real pressure, Pls help and see if this is correct?
Solver: simpleFoam
External Flow, but the b.c. settings as in a wind tunnel case, with outflow's constant pressure=0 (fixedValue);
The case is a case flow around a circular cylinder,
** For a given Re number the Cp (pressure coeff distribution and values should remain unchanged), So we have (in simulation)
Cp = (p-p0)/(0.5*rho*U*U)
where, p0=0 here in our simulation, rho=1Kg/m^3, U=1m/s.
in a real world - wind tunnel test, we have,
Cp = (p_real-101[kPa])/(0.5*rho_air*U_real*U_real)
If Cp distribution and values should remain unchanged for a given Re, whatever it is,
Suppose this is in a wind tunnel, let's say in our case, U_real is 10m/s, and rho_real=rho_air=1.205Kg/m^3
So we can now calculate the p_real that we want.
??> Is this procedure correct?
??> Is rho in OpenFOAM set as 1Kg/m^3?
Daniel WEI
Beijing, China
Email
Old   March 10, 2011, 21:18
lin
Hua Zen
simplefoam is for incompressible case. The pressure used in the calculation is actually pressure/density.
To calculate the form drag of an incompressible case, you only need the relative value of the pressure, you do not need the real value.
Thread Tools
Trackbacks are On
"Pressure Inlet" Boundary Setup Wijaya FLUENT 14 August 26, 2015 06:02
UDF issue MASOUD Fluent UDF and Scheme Programming 14 December 6, 2012 14:39
reference pressure and relative pressure in CFX and real gas setting nuimlabib Main CFD Forum 0 October 12, 2010 20:55
mass flow in is not equal to mass flow out saii CFX 2 September 18, 2009 08:07
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
