cyclic boundary condition
Like Tree7Likes
Old   March 10, 2011, 11:38
Default cyclic boundary condition
huxiaoxia
huxiaoxia is on a distinguished road
I want to simulate the thin liquid film flow on the substrate and I need the periodic boundary condition for left, right, front and back sides of the domain. However, only the front and back sides work. When I put the cyclic BC on left and right, it shows the error "Attempt to cast type wall to type lduInterface". Does anyone know what's the problem and how to solve it?
Thanks.
huxiaoxia is offline   Reply With Quote
Old   March 10, 2011, 11:49
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi
This error shows up, because there is a mismatch between the boundary condition in your variables, i.e. type cyclic; , and the type of boundary condition in your boundary file in <case>/constant/polyMesh/boundary. In the latter, the boundary type is set to wall, but it should be set to cyclic.
I have experienced problems in changing boundary type in my blockMeshDict and running blockMesh, however, this does not always change the boundary file.
Best regards,
Niels
sadjad.s, large_eddy and Aaron_L like this.
ngj is offline   Reply With Quote
Old   March 10, 2011, 13:12
Default cyclic BC
huxiaoxia
Thanks a lot.
Old   March 14, 2011, 14:18
Default Cyclic BC
longamon's Avatar
David Aljure
Location: CTTC Universidad Politécnica de Catalunya. Spain
longamon is on a distinguished road
Thanks for this, I was all afternoon trying to understand why the paraFOAM exited when I tryed to view the initial conditions (very knew to OF).
longamon is offline   Reply With Quote
Old   April 13, 2011, 06:34
HuyHoang
bongbongxanh is on a distinguished road
Originally Posted by huxiaoxia View Post
Thanks.
Dear huxiaoxia,
Your subject happens to be my graduating thesis. I'm trying to set boundary condition for the case. Unfortunately, i don't know how to use the cyclic boundary condition, i can't set the pressure drop on the opposite cyclic planes like i did in fluent . Can you tell me how you set up your case, especially the cyclic boundary condition (i.e the pressure drop, the mass flow rate ). I use the solver InterDyMFoam. I investigates the openFoam - 1.6-ext example, the channel395 but it's seems helpless until now.
I'm very grateful if you can help. Thanks in advance
Hduy
bongbongxanh is offline   Reply With Quote
Old   April 13, 2011, 07:37
maddalena's Avatar
maddalena
maddalena will become famous soon enough
Originally Posted by bongbongxanh View Post
Dear huxiaoxia,
Hduy
If you want to fix a pressure drop between the two sides of a patch, than you should use a fan bc. Search in the forum for it.
mad
bongbongxanh, mgg and Aaron_L like this.
maddalena is offline   Reply With Quote
Old   April 13, 2011, 22:16
HuyHoang
thank Maddalena
your comment have just saved my day :d
Btw, last night i had a look at channel foam in the tutorial of OpenFoam. It use the pressure drop at two opposite cyclic planes to create a gradient pressure. I just have a thought to implement this method in the interDyMFoam solver. My work have just begun, do you have any recommend ?
Old   April 14, 2011, 02:30
maddalena's Avatar
maddalena
thank Maddalena
Well, fan is a BC, thus you can use it with every solver you like without modification! I use it in every of my simpleFoam cases, but also if using chtMultiRegionFoam!
mad
Old   April 14, 2011, 22:03
HuyHoang
Hi maddelena,
Have you ever tried the fan bc on the 3d case. I have some unexplainable result in simulation
Old   April 15, 2011, 03:09
maddalena's Avatar
maddalena
Well, I do it in almost every of my simulations...
There are some issues with the fan bc you must take care of. There are some thread I have written about the subject, please search in the forum for them...
mad
Old   April 20, 2011, 10:30
Default cyclic BC
  #11
huxiaoxia
Dear HuyHoang:
Sorry to reply you late. First of all, in constant/polyMesh/blockMeshDic, you have to define the cyclic boundary, e.g
cyclic back
(0 2 3 1)
(6 7 9 8)
Then , when you define all the initial or boundary conditions under the folder 0, simply use the type cyclic. e.g
back
type cyclic;
Is it clear for you?
Old   May 17, 2011, 06:07
Default setting cyclic BC
  #12
Nicolas
NicolasB is on a distinguished road
For a better understanding of OF, I'm trying to set up the Fluent's tutorials in OF.
I'm currently working on the second tutorial about Modeling Periodic Flow and Heat Transfer, with periodic conditions.
Here is what I've made:
- copy the caelinux-1.7.0/run/tutorials/heatTransfer/buoyantBoussinesqSimpleFoam/hotRoom tutorial;
- delete the constant/polyMesh directory;
- transform the mesh provided with Fluent's tutorial using the command
fluentMeshToFoam -scale 0.01 tubebank.msh
- write and execute a createPatchDict;
- copy and modify files from 0 to 1;
- prompt a foamJob buoyantBoussinesqSimpleFoam.
The point is the results are far from those obtained in Fluent, and I'm quite certain I've failed in setting up the cyclic BCs.
It would be pretty nice if someone should help me.
See the attachments for my case (due to its size, I can't join the mesh here nor the tutorial's pdf, but if you're interested in, I'd be pleased to send them by email)
File Type: gz tuto2_buoyantBoussinesqSimpleFoam.tar.gz (46.7 KB, 192 views)
NicolasB is offline   Reply With Quote
Old   April 12, 2013, 02:20
Esmaeil Ahmadiyan
e.ahmadiyan is on a distinguished road
Hi dear foamers
I am working with dsmcFoam and trying to modeling a cyclic boundary conditions in a channel. My case is freeSpacePeriodic in /run/discriteMethods/dsmcFoam/freeSpacePeriodic directory.
Boundary file in this case is as below:
6
xPeriodic_half0
type cyclic;
nFaces 256;
startFace 14464;
matchTolerance 0.0001;
neighbourPatch xPeriodic_half1;
xPeriodic_half1
type cyclic;
nFaces 256;
startFace 14720;
neighbourPatch xPeriodic_half0;
yPeriodic_half0
type cyclic;
nFaces 320;
startFace 14976;
neighbourPatch yPeriodic_half1;
yPeriodic_half1
type cyclic;
nFaces 320;
startFace 15296;
neighbourPatch yPeriodic_half0;
zPeriodic_half0
type cyclic;
nFaces 320;
startFace 15616;
neighbourPatch zPeriodic_half1;
zPeriodic_half1
type cyclic;
nFaces 320;
startFace 15936;
neighbourPatch zPeriodic_half0;
Then I have changed this boundary file as below:
6
xPeriodic_half0 //(wall)
type wall;
nFaces 256;
startFace 14464;
xPeriodic_half1 //(outlet)
type cyclic;
nFaces 256;
startFace 14720;
yPeriodic_half0 //(inlet)
type cyclic;
nFaces 320;
startFace 14976;
yPeriodic_half1 //(wall)
type wall;
nFaces 320;
startFace 15296;
zPeriodic_half0 //(frontAndBack)
type empty;
nFaces 320;
startFace 15616;
zPeriodic_half1 //(frontAndBAck)
type empty;
nFaces 320;
startFace 15936;
But when I run this case give this error :
--> FOAM FATAL ERROR:
face 0 area does not match neighbour by 22.22222222% -- possible face ordering problem.
patchutlet my area:64 neighbour area:80 matching tolerance:0.0001
Mesh face:1 fc-5 0 0)
Neighbour fc0 4 0)
If you are certain your matching is correct you can increase the 'matchTolerance' setting in the patch dictionary in the boundary file.
Rerun with cyclic debug flag set for more information.
From function cyclicPolyPatch::calcTransforms()
in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 220.
FOAM exiting
Please help me to resolve this error and please introduce a tutorial about cyclic BC modeling for me.
Thanks a lot.
Best regards
e.ahmadiyan
e.ahmadiyan is offline   Reply With Quote
Old   April 12, 2013, 03:52
maddalena's Avatar
maddalena
Hi e.ahmadiyan,
maybe more detail can help us to understand what you want to do.
what openfoam version are you using? hat is your geometry? do you want to create cyclic or do you want to take given geometry and delete cyclic?
mad
Old   April 12, 2013, 04:16
Esmaeil Ahmadiyan
Hi maddalena
Thanks for your reply
I am using openFoam 2.0.1 and my geometry is a cubic L shape channel as show in the attached image Screenshot.jpg
I want to give cyclic BC in inlet and outlet
Best
e.ahmadiyan
Old   April 12, 2013, 04:29
maddalena's Avatar
maddalena
Answer is quite simple then...
type cyclic;
nFaces 256;
startFace 14720;
type cyclic;
nFaces 320;
startFace 14976;
Two faces are not equal at all!
My suggestion is to create a mesh using blockMesh or your preferred meshing software and then run createPatch.
mad
Old   April 12, 2013, 04:55
Esmaeil Ahmadiyan
Whats your mean about two faces are not equal?
Could is salome be a good meshing software? What is your suggestion about preferred meshing software?
In fact when we use of createPatch utility?
Tanks again.
Best.
e.ahmadiyan
Old   April 12, 2013, 05:00
maddalena's Avatar
maddalena
Two faces are not equal since cell number is different!
You can use whatever you want as meshing software or utility. After you have a mesh, you use createPatch to crete cyclic.
Good luck.
mad
Old   April 12, 2013, 05:04
Esmaeil Ahmadiyan
Thanks dear maddalena
Good luck.
e.ahmadiyan
Old   April 14, 2013, 12:50
Esmaeil Ahmadiyan
Hi dear maddalena
I have creates a mesh with salome and uses of createPatch and creates a cyclic BC but I have received to below error:
FOAM Serious Error :
From function cyclicPolyPatch:rder(const primitivePatch&, labelList&, labelList&) const
No base point for face 15903, 4(5708 6065 6066 5709), produces a valid tet decomposition.
All my test case...
cyclic.zip
Have you any suggestion?
Best regards.
e.ahadiyan
Boundary Conditions Thomas P. Abraham Main CFD Forum 20 July 7, 2013 05:05
Mixed/Robin boundary condition aaev OpenFOAM Bugs 2 December 15, 2011 14:03
cyclic boundary condition doesn't work in a tube ?? Cyp OpenFOAM 6 April 16, 2010 15:21
fan cyclic boundary condition leejc OpenFOAM 0 April 15, 2010 16:38
How to set boundary condition in Fluent for the fo Peiyong FLUENT 1 November 10, 2006 11:44
