-   -   How to change density in OpenFoam (http://www.cfd-online.com/Forums/openfoam-solving/86058-how-change-density-openfoam.html)
zhaowei March 13, 2011 17:34
Hi, all
I have done some simulation of aircraft propeller using MRFSimpleFoam, and the result goes well with ANSYS CFX. MRFSimpleFoam is used for incompressible steady state simulation. Now I want to change the flow density to see the performance of the propeller. It is very easy to change it in CFX, but how can I change the density of flow in OpenFoam?
I have read some theads said that OpenFoam use kinematic viscosity which is normalized by the density, and pressure is too. I have changed the reference pressure in fvSolution and mu in transportProperties, but the axial thrust does not change :confused:. Could anyone tell me how can I change the density? Thanks in advance.
alberto March 14, 2011 05:00
You have to change the viscosity:
nu = mu/rho
being
mu -> dynamic viscosity
nu -> kinematic viscosity
rho -> density
Best,
zhaowei March 14, 2011 05:51
Hi, Alberto
Thanks very much for your reply. I have changed the viscosity, but the axial force still not change. I use k-epsilon model, so should I change k and e?
thanks
zhaowei March 14, 2011 06:00
Oh, I forgot to post my transportProperties file.
the original one is as follows:
| \\ / O peration | Version: 1.5 |
| \\ / A nd | Web: http://www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object transportProperties;
transportModel Newtonian;
nu nu [0 2 -1 0 0 0 0] 1e-05;
CrossPowerLawCoeffs
nu0 nu0 [0 2 -1 0 0 0 0] 1e-06;
nuInf nuInf [0 2 -1 0 0 0 0] 1e-06;
m m [0 0 1 0 0 0 0] 1;
n n [0 0 0 0 0 0 0] 1;
BirdCarreauCoeffs
k k [0 0 1 0 0 0 0] 0;
zhaowei March 14, 2011 06:09
Oh, sincerely sorry everyone. I use the libturboPerformance.so to calculate the performance of rotor. I forgot to change the density there. :p:p
hz283 November 18, 2012 18:56
nu = mu/rho
being
rho -> density
Best,
Now in my simulations, there are two streams: one is air and the other is pure methane. So in this case, how to set the nu? Is it still correct to give an approximate uniform value for the whole field? Thank you very much.
hayhari February 25, 2013 05:48
Hi
I am new to openFoam. Did you get the answer for your question.?? please tell me how can we tackle this issue.. :o
cramsdead December 11, 2014 09:36
Hello hayhari,
I have just a simple question :
Is it possible to set a "density" into a block to let more or less the fluid going throught?
I mean, they is only the permeability to set it or there is other Options?
Thanks for your reply
