div(phi,U) GammaV ?
Old   March 16, 2011, 07:49
Default div(phi,U) GammaV ?
fisch
fisch is on a distinguished road
i read some parts about the Gamma Scheme in Jasak's Thesis (pages 107-110) and wanted to try it now for my openFOAM simulations. My question is now, what the Greek_Gamma value should be if i define for example:
div (phi,U) GammaV [Greek_Gamma]
In the Documentation there is a recommendation for Greek_Gamma = 1 ( i think for maximal stability).
But where is the Greek_beta_m value of the chapter in the thesis? Or is this Greek_Gamma this Greek_beta_m? Or is it not possible to define this Greek_beta_m?
What are the best values for this factor in your simulations to get max accuracy (in the best case 2nd order) and still a good convergence rate???
Thanks a lot,
Rupert
fisch is offline   Reply With Quote
Old   March 16, 2011, 08:19
akidess's Avatar
Anton Kidess
akidess will become famous soon enough
What you call Greek_Gamma is beta_m / 2.0. There is no general rule what value to pick, you'll have to play around and find what works best for you. You should not specify a value smaller 0.2 though.
akidess is offline   Reply With Quote
Old   March 16, 2011, 09:31
fisch
Thanks for your reply.
Jasak is writing in his thesis that beta should be between 0.1 and 0.5.
So do you mean that the Greek_Psi (sorry for the Gamma mistake) is two times beta? this would fit then with the bounds to Jasaks description ( beta [0.1;0.5] would lead to Psi [0.2;1]).
Or is it really 1/2* beta???
Thanks
Old   March 16, 2011, 10:23
akidess's Avatar
Anton Kidess
Oh yes, sorry about that! I did mean to say that the value you specify in the fvSchemes file will be divided by 2, which gives you the proper beta_m for the limiter (see also Gamma.H in the C++ documentation).
Old   March 17, 2011, 01:47
fisch
thank you very much
Old   August 16, 2013, 15:13
s.m
saeideh mohamadi
s.m is on a distinguished road
Dear anton
we set the the grad, div, and laplacian schemes in this way:
"gradSchemes : default cellMDLimited Gauss linear 0.5; "
"divSchemes : div(phi,U) bounded Gauss GammaV 1.0;"
"laplacianSchemes : default Gauss linear limited 0.5; "
my Question is : when we want play around to found that what value is a good limiter for GammaV , e.g we decrease the limiter of GammaV tp 0.5, we also should decrease the limiters for grad, and laplacian scheme?
or they have no relate to each other?
Thank you
s.m is offline   Reply With Quote
Difference SFCD and GammaV bboonacker OpenFOAM Running, Solving & CFD 7 March 20, 2014 11:51
