-   -   reactingFoam crashes mysteriously (http://www.cfd-online.com/Forums/openfoam-solving/86340-reactingfoam-crashes-mysteriously.html)
jose_rodrig March 20, 2011 09:30
hi forum,
I am experiencing lots of instability with the solver reactionFoam with parallelization and they are not the janafthermo sort :(
My domain has around 260 000 elements and was divided in 32 domains for parallelization - divided as (16 2 1) to minimize proc borders. Im using the chemkin reader to read a single step combustion of CH4 oxidation in a GT combustor (diffusion flames). Inlet velocities are between 20 and 50 m/s.
I started fixing Courant No to 0.1. Everything looks good for about thousands of iterations but suddenly it crashes with a floating point exception. I say suddendly because I dont see a change in timestep or even the problematic janafThermo error message.
Also, it never crashes at the same timestep: if I simply restart the solver with the same parameters (no CourantNo change or any other) it will crash in a different timeStep.
It just goes!... as you can see in the following output after decreasing CourantNo to 0.035 (it still crashes!). I also attached a txt with the complete error message. Bellow the output i also posted the fvSolution and fvSchemes so you can take and criticize.
Thank you
Josť
DILUPBiCG: Solving for epsilon, Initial residual = 4.32044e-06, Final residual = 9.94436e-09, No Iterations 1
DILUPBiCG: Solving for k, Initial residual = 1.74131e-06, Final residual = 3.09184e-09, No Iterations 1
ExecutionTime = 161537 s ClockTime = 164174 s
Courant Number mean: 0.00125684 max: 0.0349221
deltaT = 3.80307e-07
Time = 0.3549768
Solving chemistry
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for Ux, Initial residual = 1.19096e-05, Final residual = 6.46123e-09, No Iterations 1
[24] #0 Foam::error::printStack(Foam::Ostream&)[25] #0 Foam::error::printStack(Foam::Ostream&)[26] #0 Foam::error::printStack(Foam::Ostream&)[27] #0
fvSolution
solvers
rho
solver PCG;
preconditioner DIC;
tolerance 1e-06;
relTol 0;
p
solver PCG;
preconditioner DIC;
tolerance 1e-6;
relTol 0.0;
pFinal
solver PCG;
preconditioner DIC;
tolerance 1e-6;
relTol 0.0;
"(U|Yi|hs|k|epsilon)"
solver PBiCG;
preconditioner DILU;
tolerance 1e-06;
relTol 0;
PISO
nCorrectors 3;
nNonOrthogonalCorrectors 6;
relaxationFactors
rho 0.6;
U 0.6;
pFinal 0.4;
p 0.4;
k 0.6;
epsilon 0.6;
hs 0.6;
T 0.6;
fvSchemes
ddtSchemes
default Euler; //CrankNicholson 1; //Euler;
gradSchemes
default Gauss linear;
grad(p) Gauss linear;
divSchemes
default none;
div(phi,U) Gauss limitedLinearV 1;
div(phi,Yi_h) Gauss limitedLinear01 1;
div(phi,hs) Gauss limitedLinear 1;
div(phiU,p) Gauss limitedLinear 1;
div(phid,p) Gauss limitedLinear 1;
div(phi,epsilon) Gauss limitedLinear 1;
div(phi,k) Gauss limitedLinear 1;
div((muEff*dev2(grad(U).T()))) Gauss linear;
laplacianSchemes
default Gauss linear uncorrected;
laplacian(muEff,U) Gauss linear uncorrected;
laplacian(mut,U) Gauss linear uncorrected;
laplacian(DkEff,k) Gauss linear uncorrected;
laplacian(DepsilonEff,epsilon) Gauss linear uncorrected;
laplacian((rho*(1|A(U))),p) Gauss linear uncorrected;
laplacian(alphaEff,hs) Gauss linear uncorrected;
interpolationSchemes
default linear;
snGradSchemes
default uncorrected;
fluxRequired
default no;
p;
jose_rodrig March 20, 2011 10:01
error log
1 Attachment(s)
sorry, forgot the attachment
alberto March 21, 2011 04:52
does it always crash on the same equation, namely Uy?
I have a similar problem with another solver, if I use PBiCG solvers with DILU preconditioner. You might want to try with another type of linear solver for that equation to verify if it still happens.
Best,
jose_rodrig March 21, 2011 05:52
Hi alberto,
No, it crashes pretty randomly.
Actually, my simulation crashes in two ways:
a) mpi sends a message of "floating point exception" error (signal 8);
b) mpi sends a message of "Hang Up" (signal 1)
Are these 2 types of error related?
A workmate told me that openFoam sometimes hangs on opensuse (i am using 11.4): do you think this might be the problem?
alberto March 21, 2011 06:05
Originally Posted by jose_rodrig (Post 300315)
Hi alberto,
I am using the same distribution, but I use openMPI from the ThirdParty package, even though I use the system gcc compiler (4.5), so I would exclude distro-specific problems. I also observe a similar behaviour on RHEL 5.2.
Out of curiosity, do you use the system OpenMPI, the one in ThirdParty or a different version?
Best,
jose_rodrig March 21, 2011 06:15
hi,
I am using openMPI 1.4.1 from the Third Party package. I've compiled OpenFOAM myself.
regards
jose
alberto March 21, 2011 06:35
OK, we are using exactly the same configuration then. I am going to test a different MPI implementation to see if it might depend on that, and I'll let you know.
Maybe you should report it as a bug however. I reported mine, but we believed it was specific to the solver. You just confirmed it is not.
Best,
jose_rodrig March 21, 2011 08:32
Ok, I ll report my problem ASAP.
One more thing, I d like you to take a look in my other post. It is not related to this one but is also turning my head around.
Here is the link http://www.cfd-online.com/Forums/ope...dary-face.html
Regards
achinta June 26, 2012 04:42
hello reactingFoamers :),
i am new to reactingFoam solver. I am first interested in mixing of gases(without reaction). Some threads suggested reactingFoam (with chemistry switched off). I ran the solver and it crashed after 16 milliseconds. Here is my set-up
chemistry properties file
psiChemistryModel ODEChemistryModel<gasThermoPhysics>;
chemistry off; // switch off chemistry
chemistrySolver ode;
initialChemicalTimeStep 1e-07;
sequentialCoeffs
cTauChem 0.001;
EulerImplicitCoeffs
cTauChem 0.05;
equilibriumRateLimiter off;
odeCoeffs
solver SIBS;
eps 0.05;
scale 1;
Combustion properties file
combustionModel PaSR<psiChemistryCombustionModel>;
active false; //combustion switched off
infinitelyFastChemistryCoeffs
C 10.0;
PaSRCoeffs
Cmix Cmix [ 0 0 0 0 0 0 0 ] 0.1;
turbulentReaction off; //switched off
reactions file
species
O2
H2O
CH4
CO2
N2
reactions
methaneReaction
type irreversibleArrheniusReaction;
reaction "CH4 + 2O2 = CO2 + 2H2O";
A 5.2e16;
beta 0;
Ta 14906;
Thermophysical properties file
thermoType hsPsiMixtureThermo<reactingMixture<gasThermoPhysic s>>;
inertSpecie N2;
chemistryReader foamChemistryReader;
foamChemistryFile "$FOAM_CASE/constant/reactions";
foamChemistryThermoFile "$FOAM_CASE/constant/thermo.compressibleGas";
i am using SST turbulence model. Below are the boundary conditions:
mut and alphat
internalField uniform 0;
boundaryField
INLET
type fixedValue;
value uniform 0;
OUTLET
type zeroGradient;
mut for walls
type mutUSpaldingWallFunction;
value uniform 0;
alphat for walls
type alphatWallFunction;
Prt 0.85;
value uniform 0;
T:
internalField uniform 550;
boundaryField
INLET_FUEL
type fixedValue;
value uniform 293;
INLET_AIR
type fixedValue;
value uniform 550;
OUTLET
type zeroGradient;
WALL
type zeroGradient;
I don't think there could be problems with boundary conditions of U,CH4,N2,O2,k,omega and Ydefault and i won't write them here as it will lengthen the post.
There error message seems to do something with mut wall function and happens because its diverging-Tempearure is going out of range. But the Courant number is below 1. Probably, i have to improve my fvSchemes and fvSolution
fvSchemes
ddtSchemes
default backward;
gradSchemes
divSchemes
default none;
div(phi,U) Gauss linearUpwindV grad(U);
div(phi,h) Gauss limitedLinear 1;
div(phi,K) Gauss limitedLinear 1;
div(phi,omega) Gauss limitedLinear 1;
div((muEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear corrected;
default linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p;
fvSolution
solvers
rho
solver PCG;
preconditioner DIC;
tolerance 1e-06;
relTol 0.05;
rhoFinal
$rho;
tolerance 1e-06;
relTol 0;
p
solver PCG;
preconditioner DIC;
tolerance 1e-6;
relTol 0.05;
pFinal
$p;
tolerance 1e-6;
relTol 0.0;
"(U|hs||k|omega)"
solver PBiCG;
tolerance 1e-06;
relTol 0.05;
"(U|hs||k|omega)Final"
solver PBiCG;
tolerance 1e-06;
relTol 0;
Yi
$hsFinal;
PIMPLE
momentumPredictor no;
nOuterCorrectors 1;
nCorrectors 2;
nNonOrthogonalCorrectors 1;
I kindly request OpeFOAM experts to help me. I have spent lot of time on this problem. I didn't find many tutorials about reacting foam and i am not able to proceed with my simulation.
Regards,
Achinta
comingdaytime August 4, 2015 10:18
Originally Posted by jose_rodrig (Post 300223)
hi forum,
Thank you
Josť
Time = 0.3549768
Solving chemistry
fvSolution
solvers
rho
solver PCG;
preconditioner DIC;
tolerance 1e-06;
relTol 0;
p
solver PCG;
preconditioner DIC;
tolerance 1e-6;
relTol 0.0;
pFinal
solver PCG;
preconditioner DIC;
tolerance 1e-6;
relTol 0.0;
solver PBiCG;
tolerance 1e-06;
relTol 0;
PISO
nCorrectors 3;
relaxationFactors
rho 0.6;
U 0.6;
pFinal 0.4;
p 0.4;
k 0.6;
epsilon 0.6;
hs 0.6;
T 0.6;
fvSchemes
ddtSchemes
gradSchemes
divSchemes
default none;
laplacianSchemes
default linear;
snGradSchemes
fluxRequired
default no;
p;
Hey,
I saw in your case, fvSolution, you used PISO algorithm. But when I don't define PIMPLE in the fvSolution, there will be an error message. Do you think the PIMPLE keyword is required necessarily?
Thank you
Bes Regard
Litchy
