Home > Forums > OpenFOAM Running, Solving & CFD
Problem with simpleFoam
Old   March 21, 2011, 10:02
Default Problem with simpleFoam
salvoblack is on a distinguished road
Dear foamers, i have a problem.
Every time I do a calculation with simpleFoam, I have problems related to the type of mesh used. In fact, using an airfoil, if I use a fairly low number of cells as 20,000 I get acceptable results, but if my airfoil is thicker (70000) of the cells i have completely absurd results : the solution diverges. I do not change anything between the various settings, change only the mesh. could you tell me if there is a parameter that should be changed depending on the quality of the mesh??
salvoblack is offline   Reply With Quote
Old   March 21, 2011, 11:22
Mirko Vukovic
mirko is on a distinguished road
You may have to decrease the time step. Check your courant number.
mirko is offline   Reply With Quote
Old   March 22, 2011, 05:41
I use the cam to calculate the Co courant in openFoam?
Old   March 22, 2011, 06:15
maddalena's Avatar
maddalena
maddalena is on a distinguished road
If using simpleFoam the Co is useless, since the simulation is steady state!
Salvo, could you post checkMesh of the old (coarse) mesh and the new (finest) mesh? How do you made the refinement? Increasing the cell number does not mean that you improve mesh quality!!!
What about y+ values?
Have you try to see where the problem may be using simpleFoamResiduals?
mad
maddalena is offline   Reply With Quote
Old   March 22, 2011, 10:23
hi maddalena,sorry for my english.
i put in the terminal Co so i have the Courant number for my mesh.
I have a very very high value of this number:6*10^6. i think that this is the problem for my case.
i know that i can impose Co=1 knowing the distance between cells and the time step. How can I calculate these factors for my mesh???I don't know how calcolate the distance between cells
thanks
Old   March 22, 2011, 17:01
maddalena's Avatar
maddalena
Hi Salvo,
thanks
your English is not a big issue as far as I can understand your problem.
However... are you really using simpleFoam? If so, than Co has no meaning at all! See equation 2.2 here In your case you should have set deltaT=1, since simpleFoam is a steady state solver, thus deltaT is an iteration counter only! If you want, delete the maxCo line in controlDict file. simpleFoam should no complain about this missing entry, since it does not need it.
In conclusion: the problem lies somewhere else...
mad
Old   March 23, 2011, 03:54
thank you for yor help, maddalena. i decided to re-make the mesh!!!
just a curiosity, are you italian??
Old   March 23, 2011, 03:56
maddalena's Avatar
maddalena
Yes, I am. That is probably way I can understand your english easily: it is similar to mine!
mad
Thread Tools
Trackbacks are On
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 05:29
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
