reactingFoam vs rhoReactingFoam
Old   March 23, 2011, 09:31
Default reactingFoam vs rhoReactingFoam
Scot Johnson
Scot is on a distinguished road
I just downloaded OpenFOAM (1.7.1) (SUSE linux) and I got reactingFoam but did not get rhoReactingFoam. Would someone be so kind as to compare and contrast the two? Why use one versus the other? I see reactingFoam uses hCombustionThermo.H and psiChemistryModel.H while rhoReactingFoam uses hReactingThermo.H and rhoChemistryModel.H. What am I missing by not having rhoReactingFoam? Thanks!
Scot is offline   Reply With Quote
Old   April 5, 2011, 17:08
Luigi
Hìr0 is on a distinguished road
I'm also interested.....
Hìr0 is offline   Reply With Quote
Old   May 20, 2011, 07:18
Illya Shevchuk
linch is on a distinguished road
same for me
linch is offline   Reply With Quote
Old   May 22, 2011, 07:29
edison
Edison_Ge is on a distinguished road
same here
And I'm interested in a incompressible combustion solver, any suggestion?
Edison_Ge is offline   Reply With Quote
Old   July 9, 2014, 08:21
Default Incompressible ReactingFoam
James
ni-openfoam-user is on a distinguished road
Dear colleagues,
Did you ever get an answer to your question or resolve this issue?
I am attempting to simulate a high pressure hydrogen release from a pipe using ReactingFoam (release only = no chemistry and no reaction) and wish to run it as an incompressible flow (simplification)
Is it possible to modify the ReactingFoam solver from compressible to incompressible?
Many thanks,
James
ni-openfoam-user is offline   Reply With Quote
Old   April 5, 2016, 08:24
AdOo
adrieno is on a distinguished road
anyone able to answer in 2016 ?
adrieno is offline   Reply With Quote
Old   April 16, 2016, 13:25
Retired Super Moderator
Bruno Santos
Quick answers:
  1. Reason why the two solvers exist:
    1. Description in the source code for reactingFoam:
      Solver for combustion with chemical reactions.
    2. Description in the source code for rhoReactingFoam:
      Solver for combustion with chemical reactions using density based thermodynamics package.
  2. You can do incompressible flow by configuring the file "constant/thermophysicalProperties" as an incompressible fluid. Run the following command to look for examples:
    find $FOAM_TUTORIALS -name thermophysicalProperties
  3. As to why an explicit implementation of incompressible combustion solver doesn't exist, it is most likely because the developers of OpenFOAM aim for generic implementations, to minimize maintenance. For example, see this bug report: http://www.openfoam.org/mantisbt/view.php?id=1856
Old   April 18, 2016, 03:03
AdOo
thank you for your reply wyldckat,
Sorry for my ignorance but how did you see that ? I mean in the source code ?
Old   June 2, 2016, 11:28
Mr.liu
lx882211 is on a distinguished road
Originally Posted by wyldckat View Post
Quick answers:
I meet a problem in Openfoam 2.3.0, reactingFoam, i need the data of CH4 reaction rate, but i failed to autowrite it like U or Yi.
First i added this code in the CreatField.H,
volScalarField Rrate
IOobject
"Rrate",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::AUTO_WRITE
mesh,
dimensionedScalar("Rrate", dimMass/dimVolume/dimTime, 0.0)
Then, i added this code in YEqn,
forAll(Y, i)
if (Y[i].name() != "CH4")
RR = reaction->R(Yi);
After wmake, it shows
YEqn.H:26:14: error: no match for ‘operator=’ (operand types are ‘Foam::volScalarField {aka Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>}’ and ‘Foam::tmp<Foam::fvMatrix<double> >’)
Rrate = reaction->R(Yi);
Can you tell me how to do that? Thank you very much.
lx882211 is offline   Reply With Quote
help with reactingFoam piccinini OpenFOAM 8 October 4, 2013 05:08
reactingFoam wedge handling wrong U dhondupant OpenFOAM Bugs 1 December 9, 2010 07:34
reactingFoam floating point exception pajofego OpenFOAM 0 November 6, 2010 17:29
reactingFoam - turbulent reacting flow hamburgFoam OpenFOAM 0 December 7, 2009 12:57
solver settings for reactingFoam leejc OpenFOAM 1 July 23, 2009 10:19
