-   -   p_rgh in OpenFOAM 1.6 (http://www.cfd-online.com/Forums/openfoam-solving/86623-p_rgh-openfoam-1-6-a.html)
vkrastev March 28, 2011 14:16
Hi all, I'm trying to modify the chtMultiregionFoam solver of OpenFOAM 1.6 adding some of the characteristics of the 1.7.1 version. Apart from the details, I need the 1.6 solver to recognize p_rgh as the new pressure variable for which the solution procedure is performed. I've modified the pEqn.H file in order to reach the goal, but after a seemingly correct compilation when I try to run a test case this is the error message coming out:
Solving for fluid region fluid1
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 2.5150392e-08, No Iterations 2
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 9.5553996e-09, No Iterations 2
DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 6.502438e-09, No Iterations 2
DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 3.847947e-09, No Iterations 2
Min/max T:300 363
keyword p is undefined in dictionary "/work/alh/vesselin/myMultiRegionCase_4_liquid/system/fluid1/fvSolution::solvers"
file: /work/alh/vesselin/myMultiRegionCase_4_liquid/system/fluid1/fvSolution::solvers from line 21 to line 124.
From function dictionary::subDict(const word& keyword) const
in file db/dictionary/dictionary.C at line 449.
FOAM exiting
Any suggestion to fix the problem? Is it possible to redefine the keyword for the pressure variable?
Thank you in advance
V.
PS-Please, do not answer: "Switch to OF-1.7.1 instead of breaking your head on how to modify the 1.6 version...". I know this could be the simplest solution bur unfortunately I must do it the above way....
vkrastev March 29, 2011 05:00
Maybe it could be more appropriate to shift the post here http://www.cfd-online.com/Forums/ope...tml#post301338
V.
ata March 30, 2011 09:29
I think you must change the name of the p to p_rgh in your code or p_rgh to p in you solution dictionaty. But if I mistake, you can upload your code for more help.
