Home > Forums > OpenFOAM Running, Solving & CFD
Problem with Aerofoam for OF1.7.1
Like Tree1Likes
  • 1 Post By Emilie
Old   April 6, 2011, 03:49
Exclamation Problem with Aerofoam for OF1.7.1
Emilie Garnier
Emilie is on a distinguished road
Hello everybody,
I'm trying to use the solver AeroFoam with the 1.7.1 version of OF; it's part of an important project for my study. I downloaded the Aerofoam files at :
https://sourceforge.net/projects/aerofoam/files/Source/
And now I want to test this solver with a tutorial case : the oblique shock.
However, (after 'BlockMesh'), when I launch AeroFoam, I have :
Create time
Create mesh for time = 0
Reading Thermodynamic Properties...
gamma [-] = 1.4
Pr [-] = 0.72
R [J/KgK] = 287.05
Cp [J/KgK] = 717.625
Cv [J/KgK] = 1004.67
Reading Initial Conditions...
Reading field p
Reading field T
Reading field U
Creating conservative variables at t^(k)
Creating conservative variables at t^(k-1)
Creating conservative variables at t^(k-2)
Creating conservative variables fluxes at t^(k)
Creating primitive variables gradient fields (optional)
Creating Mesh Connectivity...
Using adaptive algorithm...
id_LL_i7290SIZE3510Loop on Internal Faces...
i=0i=1i=2i=3i=4i=5i=6i=7i=8i=9i=10i=11i=1
until i=3509
Loop on Boundary Faces...
Mesh
# of Faces = 3510
# of Cells = 1800
# of BndPatch = 5
0) inlet @ top
1) supersonicInlet @ inlet
2) extrapolatedOutlet @ outlet
3) symmetryPlane @ bottom
4) empty @ frontAndBack
Numerical Scheme
flowType = Euler
timeScheme = RK2
CourantMax = 0.1
CourantSteps = 25
MonotoneFlux = Roe
HighResFlux = LW
fluxLimiter = VL
entropyFix = HH2
extrapolateBC = 1
residualNorm = L1
minResidual = -1
Does everything look fine? [y] to continue [n] otherwise
I type yes and get :
blf fx i=1
blf fx i=3509
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam171/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigSegv::sigSegvHandler(int) in "/opt/openfoam171/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 in "/lib/libc.so.6"
at Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh>*, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>*, Foam::word, Foam::word, Foam::word, Foam::word, double)
in "/home/emilie/OpenFOAM/bruno-1.7.1/applications/bin/linux64GccDPOpt/AeroFoam"
#5 __libc_start_main in "/lib/libc.so.6"
Segmentation fault
Does anyone has an idea why I have this error ?
Thank you very much for your help !
Emilie
aerothermal likes this.
Emilie is offline   Reply With Quote
Old   June 17, 2011, 03:35
TCH
Solarberiden is on a distinguished road
could you please rebuild your openfoam in debug mode and repost the error message? The final error message you posted didn't bring forwards any location about the error position information, which is a little bit difficult for other "depanner" , LOL.
by the way, the author of the version you are using and downloading from sourceforge JLight2010 had mentioned that
hypersonic cfd free code???
he is not sure about the code correctness, further discuss would be depending your reply, I have tried some examples including the OneraM6 case and YF-17 case.
Solarberiden is offline   Reply With Quote
Old   June 21, 2011, 06:17
Unhappy Stuck!!
Rachit Prasad
Rachit is on a distinguished road
Hi everyone!
I am a new of OpenFOAM and hence AeroFoam as well. In order to get familiar with it, I went to the following website and downloaded the Oblique Shock Test problem:
http://www.aero.polimi.it/freecase/?...:Oblique_shock
After uncompressing the folder, I tried to run it, but the following came on the terminal:
This is a start/*---------------------------------------------------------------------------*\
| \\ / O peration | Version: 1.6 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 1.6-53b7f692aa41
Exec : AeroFoam
Date : Jun 21 2011
Time : 16:02:27
Host : rachit-desktop
PID : 5378
Case : /home/rachit/OpenFOAM/OpenFOAM-1.6/foam_run/compressible/ObliqueShock_B/ObliqueShock_B
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
// using new solver syntax:
cellDisplacement
solver PCG;
preconditioner DIC;
tolerance 1e-08;
relTol 0;
gamma [-] = 1.4
Pr [-] = 0.72
R [J/KgK] = 287.05
Reading field p
Reading field T
Reading field U
id_LL_i6500SIZE3100Loop on Internal Faces...
Nothing happens beyond this, as in the process is still continuing but no progress is being made.
Could anyone please tell me what mistake I am making?
Thanks in advance!
Rachit
Rachit is offline   Reply With Quote
Old   September 27, 2011, 04:15
ThanhToan
trantoan2008 is on a distinguished road
Send a message via Yahoo to trantoan2008 Send a message via Skype™ to trantoan2008
Hi All,
I had the same problem like you when I tried to use AeroFoam solver to test that case. Is there anybody treat this problem?
trantoan2008 is offline   Reply With Quote
Old   December 5, 2011, 15:43
aerothermal's Avatar
Guilherme da Silva
aerothermal is on a distinguished road
I had same problem here when running the Onera M6 wing test case downloaded from AeroFoam site and using AeroFoam for OF1.7.1.
Originally Posted by Emilie View Post
Hello everybody,
Create time
gamma [-] = 1.4
Pr [-] = 0.72
R [J/KgK] = 287.05
Reading field p
Reading field T
Reading field U
until i=3509
Mesh
# of Faces = 3510
# of Cells = 1800
# of BndPatch = 5
0) inlet @ top
Numerical Scheme
flowType = Euler
timeScheme = RK2
CourantMax = 0.1
CourantSteps = 25
MonotoneFlux = Roe
HighResFlux = LW
fluxLimiter = VL
entropyFix = HH2
extrapolateBC = 1
residualNorm = L1
minResidual = -1
blf fx i=1
blf fx i=3509
Segmentation fault
Emilie
aerothermal is offline   Reply With Quote
Thread Tools
Trackbacks are On
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Incoherent problem table in hollow-fiber spinning Gianni FLUENT 0 April 5, 2008 10:33
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
convergence problem Trushar Phoenics 5 August 27, 2002 23:40
