Hypersonic flow rhoCentralFoam
1 Attachment(s)
I tried to simulate a hypersonic flow through a scram-jet engine in rhoCentralFoam but a Normal shock is getting generated as you can see that in the attached picture. Same thing is happening when I tried to use sonicFoam. I really don't know the reason, Please help. the BC are pressure: internalField uniform 139.81; boundaryField { inlet { type fixedValue; value uniform 139.81; } outlet { type zeroGradient; } ............................ temperature: internalField uniform 123.12; boundaryField { inlet { type fixedValue; value uniform 123.12; } outlet { type zeroGradient; } ...................... velocity: internalField uniform (0 0 0); boundaryField { inlet { type fixedValue; value uniform (1778.711 0 0); } outlet { type zeroGradient; } ............... Thanks Regards, Ishan |
