May 9, 2011, 13:24 |
pressure driven flow in interFoam
Nico T
I'm working on open channel flow using interFoam. A case with fixedValue-BC for U at the inlet and p_rgh fixedValue-BC at outlet is working properly (zeroGradient BC at outlet for U and inlet for p_rgh). But is it possible to implement a pressure drop by specifying inlet AND outlet pressure fixedValue-BC (channel slope), without a fixedValue-BC for U? Thus, U should be developed corresponding to the pressure gradient. I tried zeroGradient and pressureInletOutletVelocity for U-inlet and outlet, but the runs failed. Which BC for U would be appropriate for thise case? Thanks for your help, Nico |
May 9, 2011, 15:25 |
Santiago Marquez Damian
Rep Power: 23 |
What about totalPressure for p_rgh and zeroGradient for U and alpha1 at inlet?
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D. Research Scientist Research Center for Computational Methods (CIMEC) - CONICET/UNL Tel: 54-342-4511594 Int. 7032 Colectora Ruta Nac. 168 / Paraje El Pozo (3000) Santa Fe - Argentina. http://www.cimec.org.ar |
May 11, 2011, 08:40 |
Nico T
Hi, thanks for your answer,
I tried also totalPressure for inlet and outlet of p_rgh with no success. totalPressure is also set for the top of the channel = atmosphere. For alpha1, I forgot to mention, I use groovyBC at inlet for time varying waterlevel. Maybe that's the problem? Regards. |
June 24, 2011, 11:11 |
Benjamin Mandt
I have the same problem trying to calc a flooding inside a ship, only with pressure given at the inlet side. In a personal discussion at another forum, I received this answer (the discussion was in german, I try to translate it): " Hydrostatic pressure boundary condition calculated as pRefValue + rho*g.(x - pRefPoint) where rho is provided and assumed uniform. " for the inlet pressure: "uniformDensityHydrostaticPressure" the velocity at the inlet: "pressureInletUniformVelocity" water at the inlet: alpha/gamma = fixedValue; value uniform 1; at the outlet "zeroGradient"for using Piso unfortunately the author mentioned piso, not interfoam, but it may be, and I hope this, this information helps you. I was not able to set up an interfoam case with this information, the reason may be, that I am a very beginner at openfoam and cfd... I hope you will give feedback. Best regards Benjamin |
June 25, 2011, 08:13 |
HuyHoang
i suggest convert the pressure drop at the boundary condition into a pressure source, i.e. a constant gradient of pressure in the desired flow direction and add it to momentum equation in the solver. the velocity at the boundary can be set at zeroGradient or inletOutlet, the velocity itselft will then be driven by the pressure source and develop over the length of the channel.
Hope this idea can help. |
June 25, 2011, 15:42 |
Nima Samkhaniani
Rep Power: 24 |
look into channelFoam, you can download channelInterFoam here, but i cant promise its totally true
http://www.4shared.com/file/75DpcP1g...InterFoam.html |
October 11, 2011, 06:45 |
Andrea Ferrari
Hi Nico,
Have you found a solution? Have you tried channelFoam? I need to specify a pressure gradient between the inlet and the outlet of my domain and i would like that the flow was driven by this gradient. Best andrea |
October 12, 2011, 03:52 |
Andrea Ferrari
Hi nima and thanks for reply.
I never used fan BC, can you be a bit more specific about how to use them for my case? or can you direct me to some reference or tutorial? thanks again andrea |
October 13, 2011, 04:51 |
Nico T
Hi nimasam,
thanks for your help. I tried to use fan BC. But I use groovyBC for defining the water level at the inlet. Therefore, cyclic fan BC does not work, because "inout" (cyclic patch of inlet & outlet) can not be defined by groovyBC?! Nico |
October 13, 2011, 06:00 |
#12 |
Nico T
ok! defining water level at time 0 by using setFields works. water level stays constant through the simulation.
thank you very much! |
October 18, 2011, 07:28 |
#13 |
Andrea Ferrari
Hi again,
I understand how to define a "inout" cyclic patch between inlet and outlet. Now my question is which is the correct boundary condition for alpha1 in "inout"? i have 0/U inout { type cyclic; value uniform (0 0 0); } 0/p_rgh inout { type fan; patchType cyclic; f List<scalar> 1(1000); value uniform 0; } 0/alpha1 inout ?? Can i use the inletOutlet patch? I would like to have fixedValue at the inlet (uniform 1) and something like zeroGradient or inletOutlet at the outlet. best andrea |
October 18, 2011, 08:07 |
#14 |
Nima Samkhaniani
Rep Power: 24 |
no you can't , when you use the class cyclic, you can only use cyclic boundary condition or its sub derived class like fan
but the main question is that how ur alpha treats? is it cyclic or not? if it is not cyclic why you are going to use cyclic BC for ur simulation? |
October 18, 2011, 08:37 |
#15 |
Andrea Ferrari
Hi nima,
honestly i'm trying different types of boundary condition to see what is the best choice to reproduce an experiment. In the experiment the flow is driven by a pressure difference between inlet and outlet and I'm loking for something similar in my simulation (at least i would like to not specify the pressure at outlet, because i'm interesting in what happens at the breakthrough and i think fixed pressure BC affects the results). Probably you are right and my alpha1 is not cyclic because i want only phase1 which enters at the inlet and not a mix of the two (which is what flows out at the outlet). the problem remains! if you have other ideas, of course are welcome. best andrea |
September 13, 2013, 04:57 |
#16 |
This maybe an old thread, but did you found any solution for this?
Learn OpenFOAM in Persian SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member Complex Heat & Flow Simulation Research Group If you can't explain it simply, you don't understand it well enough. "Richard Feynman" |
September 13, 2013, 08:51 |
#17 |
Nima Samkhaniani
Rep Power: 24 |
solution for what?
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
September 13, 2013, 12:36 |
#18 |
To solve for pressure driven flow using interFoam.
I mean the boundary conditions. I don't know why not typical boundaries converge for this case. P value must be greater that a specific value (i.e 20000 Pa) to be able to drive the flow. But the one I want it to be is about 1000 Pa. With this lower value I can not converge the solution.
Learn OpenFOAM in Persian SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member Complex Heat & Flow Simulation Research Group If you can't explain it simply, you don't understand it well enough. "Richard Feynman" Last edited by Mojtaba.a; September 13, 2013 at 13:58. |
September 13, 2013, 13:21 |
#19 |
Nima Samkhaniani
Rep Power: 24 |
i have no idea, you may want to setup a simple test case and show this, which may help other OpenFOAM user help you to find out how to solve this problem
November 13, 2015, 07:16 |
Channel flow bc's at inlet
#20 |
Saideep
Rep Power: 11 |
Hi guys;
I would like to revoke this old thread. For a 1 phase flow, pressure gradient between inlet and outlet works perfectly whereas this is not the case for a 2phase flow in interFoam. Can anyone shed some light over that. My case: it is simple channel flow with one phase being invaded by an other phase. My ideal bc's would be is to specify inlet and outlet bcs for pressure and let the velocity develop over the channels flow physically. I tried this but it doesn't work whereas when i try to invade it by specifying injection velocity at inlet and 0 pressure at outlet i have a flow. Could anyone who already solved your problem for a similar case help me out with suitable bcs, Saideep |
Compressible flow, no data at the outlet | mireis | FLUENT | 6 | September 3, 2015 02:10 |
Simulating a high pressure flow through a valve | Kromagnsss | FLUENT | 8 | July 2, 2010 05:20 |
pressure BC in buoynacy driven flow | Sasha | FLUENT | 3 | October 11, 2006 10:08 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 13:19 |
