May 13, 2011, 16:18 |
Turbulence Inflow
Daniel WEI (老魏)
Rep Power: 21 |
Hi guys,
I hope this discussion is not too late. Is there anybody who has experience in importing the turb from another separated simulation at the inlet? Question 2 is, I wonder how you guys check your turb inflow quality? By spectrum, correlation, friction coefficient, transition, coherent structures or what? Any ideas? I read some papers on this, but I'd still like to hear your valuable experience. Thanks (PS: please identify your turbulence type, channel turb, boundary layer turb, or others) Best Regards, Daniel
~ Daniel WEI ------------- Boeing Research & Technology - China Beijing, China |
May 18, 2011, 03:49 |
Dejan Morar
Hi Daniel,
Which papers have you read? Can you suggest one? How do you usually generate initial turbulent field? I need initial turbulence for my channel-flow like simulation (geometry is little bit complicated). Thanks, Dejan |
May 18, 2011, 14:06 |
Daniel WEI (老魏)
Rep Power: 21 |
Search for Dr. Tabor and Dr. Mohammad paper, and go to his reference section, it will have almost everything you need. It's a good review.
Turbulence inflow generation - recycling method | panda60 | OpenFOAM Running, Solving & CFD | 15 | April 25, 2013 01:34 |
inflow turbulence using LES ? | panda60 | OpenFOAM | 5 | October 15, 2009 02:32 |
Discussion: Reason of Turbulence!! | Wen Long | Main CFD Forum | 3 | May 15, 2009 09:52 |
About Methods of Generating Inflow Turbulence! | Adonis | Main CFD Forum | 0 | March 30, 2006 04:02 |
