-   -   Very small recirculation length for flow over a circular cylinder (http://www.cfd-online.com/Forums/openfoam-solving/88326-very-small-recirculation-length-flow-over-circular-cylinder.html)
Tarak May 13, 2011 18:37
Hii,
I am running the circular cylinder case for Re=3900 using various LES models (oneeqeddy,locDynOneeqeddy etc), but getting very small recirculation length. I am taking a time step of 1e-4 and running till time=2 s. can someone please let me know if he/she has got correct results for a similar case?
Thanks,
Tarak
tfuwa May 31, 2011 03:19
Hi Tarak,
I have seen your two posts on the simulation of flow around a circular cylinder with LES models and currently am doing exactly the same case. My first thought on your result is that the running time is too short and 15 s should be good.
Are you doing this case in 2D or 3D? Can you give more information about the simulation?
Regards,
Albert
Tarak August 31, 2011 11:27
Hii,
Did you have any luck with this case? Were you able to get a good recirculation length? I am still not being able to get good results.
Thanks
