LES channelFoam solver underpredicts friction factor
Old   May 16, 2011, 20:47
Default LES channelFoam solver underpredicts friction factor
Harley Klein
utexasche is on a distinguished road
I am running a (periodic) pipe flow calculation using channelFoam and am unable to obtain an appropriate value for the friction factor. The case is wall-resolved, with wall-normal, span-wise and stream-wise cell dimensions (given in wall units) of 0.5, 30 and 50, respectively, with a growth rate of 1.2 within the prism layer. The Reynolds number in my test case is 50,000, and the length-to-diameter ratio, L/D, is equal to 6.
The Blausius relationship for the friction factor gives a value of f = 0.0022, but my calculation is giving a value of approximately 0.0016. I am using Alberto Passalacqua's implementation of the dynamic Smagorinsky model. Is there an inherent issue that I am overlooking in applying the dynamic model for a wall-resolved case such as this? I am using an unstructured mesh with wedges in the core and hexahedrons in the prism layers. I have tried several different LES models and filters and meshes, but nothing seems to improve the result.
I am aware of the fact that the use of an unstructured, non-uniform mesh can be an issue given the non-commutative nature of the filters, but am not sure whether or not the underprediction of the wall shear stress is an expected consequence. Does anyone have any thoughts on this? Any suggestions?
utexasche is offline   Reply With Quote
L/Δ factor for LES mesh faisal_durr ANSYS Meshing & Geometry 0 February 17, 2011 08:56
Converting RANS solver into LES Chiara Main CFD Forum 5 February 19, 2009 09:36
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
Laminar solver? LES? or DNS? Ray Main CFD Forum 5 March 19, 2003 10:19
Setting a B.C using UserFortran in 4.3 tokai CFX 10 July 17, 2001 16:25
