Home > Forums > OpenFOAM Running, Solving & CFD
epsilon groovyBC problem
Old   May 17, 2011, 17:48
Default epsilon groovyBC problem
Thomas Smyth
Thom is on a distinguished road
Hi everyone,
I am trying to create an epsilon inlet using groovyBC but am having a couple of problems. It is probably something very simple but I am hoping you can point me in the right direction!
here's my epsilon inlet condition:
inlet
         type            groovyBC;
        variables      "uStar=0.005;z0=0.05;K=0.41;epsilon=pow(uStar,3)/K(pos().z+z0)";
         valueExpression "epsilon";
     value uniform 0;
As I said sorry if this is probably very trivial but I am still very much an foam novice.
Thanks for your help and time
Thomas
Thom is offline   Reply With Quote
Old   May 18, 2011, 03:23
Assistant Moderator
Bernhard Gschaider
Originally Posted by Thom View Post
Hi everyone,
inlet
         type            groovyBC;
     value uniform 0;
Thomas
It would be easier to point you in the right direction if you said HOW the problem manifests itself.
Is your problem a syntax error? Because you're using K like a function.
Apart from that: Having a variable with the same name as the field might lead to weird behaviour (the variable should shadow the field value and your case should be alright anyway)
And one last thing: Never ever (not even for fun and not even in the "value"-field that is probably never going to be used) set epsilon to zero
Old   May 18, 2011, 05:15
Thomas Smyth
Hi Bernhard,
It was a floating point exception which led me to believe I was doing something mathematically incorrect. Thanks for pointing me in the right direction as the K was providing the problem. I appreciate your advice on the other issues too especially the epsilon value. I just realised how novice an error that was.
Thanks again for all your help,it seems to be working correctly now (hopefully!)
Thomas
Old   May 18, 2011, 11:29
Assistant Moderator
Bernhard Gschaider
Hi Bernhard,
Thomas
Interesting: you didn't get a syntax-error but a floating point exception? Strange
Old   October 25, 2012, 22:53
Gregoire Junqua
gregjunqua is on a distinguished road
Hi did you solve your problem?
I am using this equation too as :
inlet
type groovyBC
variables "u_f=0.521;z0=0.001;z_f=pos().y;K=0.4;epsi = pow(u_f,3)/(K(z_f+z0))";
valueExpression "epsi";
i also got the following error :
From function groovyBCFvPatchField<Type>::groovyBCFvPatchField(c onst fvPatch& p,const DimensionedField<Type, volMesh>& iF,const dictionary& dict)
in file groovyBCFvPatchField.C at line 119
No value defined for epsilon on inlet therefore using 100{0}
I try many solution and none is working ...
is there something i had miss? because i do it for my wind condition and it work well ...
i guess because it's not a vector but i don't know how to solve this problem
gregjunqua is offline   Reply With Quote
Old   October 26, 2012, 05:16
Assistant Moderator
Bernhard Gschaider
inlet
type groovyBC
What this warning (it is not an error because the simulation continues to run .... at that point) means is that during construction the valueExpression is not evaluated (that would lead to all kinds of circular dependencies in the cases with fields that are not yet constructed/loaded). So the constructor assumes that you define something like "value uniform 1e-2;" or so, which it uses only until all fields are being loaded. If you didn't define that groovyBC decides to play it nice and "fill in a value for you". The value that fits most situation which is 0. Problem is that 0 is not a very good choice for epsilon.
So declare an approximate 'value' for epsilon. It will only be used until all other fields are loaded. After that your valueExpression will be used
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
epsilon, groovybc
Thread Tools
Trackbacks are On
___Minus epsilon problem___ maysmech OpenFOAM 0 January 3, 2011 04:10
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 05:29
Problem with epsilon joshK OpenFOAM 1 October 8, 2010 01:55
Problem with boundary condictions in an airfoil bego OpenFOAM Running, Solving & CFD 0 September 22, 2010 05:56
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
