Home > Forums > OpenFOAM Running, Solving & CFD
rhoPimpleFoam error
Old   May 17, 2011, 23:30
Default rhoPimpleFoam error
Hossein
atoof is on a distinguished road
Send a message via Yahoo to atoof
Hi Foamers,
I run a case for two inlet air with different temperatures in a channel.
I set 0 directory as attached files.
When I use rhoPimpleFoam as a solver I faced to this error:
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted:
#3 Foam::compressible::RASModels::mutWallFunctionFvPa tchScalarField::calcMut() const in "/opt/openfoam171/lib/linuxGccDPOpt/libcompressibleRASModels.so"
#4 Foam::compressible::RASModels::mutWallFunctionFvPa tchScalarField::updateCoeffs() in "/opt/openfoam171/lib/linuxGccDPOpt/libcompressibleRASModels.so"
#5 Foam::fvPatchField<double>::evaluate(Foam::Pstream ::commsTypes) at /opt/openfoam171/src/finiteVolume/lnInclude/fvPatchField.C:222
#6 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::evaluate() at /opt/openfoam171/src/OpenFOAM/lnInclude/GeometricBoundaryField.C:306
#7 Foam::compressible::RASModels::kEpsilon::kEpsilon( Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libcompressibleRASModels.so"
#8 Foam::compressible::RASModel::adddictionaryConstru ctorToTable<Foam::compressible::RASModels::kEpsilo n>::New(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libcompressibleRASModels.so"
#9 Foam::compressible::RASModel::New(Foam::GeometricF ield<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libcompressibleRASModels.so"
#10 Foam::compressible::turbulenceModel::addturbulence ModelConstructorToTable<Foam::compressible::RASMod el>::NewturbulenceModel(Foam::GeometricField<doubl e, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libcompressibleRASModels.so"
#11 Foam::compressible::turbulenceModel::New(Foam::Geo metricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libcompressibleTurbulenceModel.so"
#12
at /opt/openfoam171/applications/solvers/compressible/rhoPimpleFoam/createFields.H:57
#13 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
#14
in "/opt/openfoam171/applications/bin/linuxGccDPOpt/rhoPimpleFoam"
Floating point exception
I guess the problem is about k-epsilon setting in 0 directory, but I don't know where is the problem.
How can I remove this error?
Regards,
Hossein
atoof is offline   Reply With Quote
Old   June 20, 2011, 07:04
Cecily
Black-Pearl is on a distinguished road
Hi Hossein,
have you solve the problem?
I have the same problem and can't find a solution.
Greetings
Black-Pearl is offline   Reply With Quote
Thread Tools
Trackbacks are On
GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM 300 October 29, 2014 19:00
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 18:43
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
user defined function cfduser CFX 0 April 29, 2006 10:58
