Illegal dictionary entry or environment variable name "0" |
January 10, 2018, 17:23 |
Çağatay Emre Ayhan
Rep Power: 8 |
I try to create a small hollow cylinder vertical to the water flow. I am trying to use conjugate steady heat transfer and find Nusselt number. I will refine the mesh in the fluid_to_solid region but now I am trying to rotate the cylinder.The folders are attached. Any help will be appreciated. Thank you very much.
I have attached a screenshot. I need to get rid of the cylinder that is parallel to the large cylinder |
Environment Variable | ziooscuro | OpenFOAM Installation | 0 | April 16, 2009 10:50 |
Setting working environment variable | Arthur | FLUENT | 0 | December 10, 2008 04:33 |
Environment variable MPI_GROUP_MAX | Satya | Siemens | 0 | May 29, 2007 02:16 |
Install Openfoam in Suse 100 setup environment | h34gk1 | OpenFOAM Installation | 1 | September 26, 2006 20:08 |
How to set environment variables | kanishka | OpenFOAM Installation | 1 | September 4, 2005 10:15 |
