Home > Forums > OpenFOAM Running, Solving & CFD
difference between inletValue and value in inletOutlet B.C.
Like Tree1Likes
  • 1 Post By su_junwei
Old   May 29, 2011, 07:34
Default difference between inletValue and value in inletOutlet B.C.
Hossein
atoof is on a distinguished road
Send a message via Yahoo to atoof
Dear foamers
I try to run a case and have a problem with inletOutlet Boundary condition.
What is the difference between the inletValue and value in this B.C.?
It seems that they have a same value in most of the cases.
regards,
Moha
atoof is offline   Reply With Quote
Old   May 29, 2011, 10:31
su_junwei's Avatar
su junwei
su_junwei is on a distinguished road
Send a message via MSN to su_junwei
inletOutlet is a back flow boundary condition for outlet. If fluid attepts to flow inwards, it applies a fixed value velocity assigned by inletValue for that given patch face. Or, it use zerogradient.
InletValue is the value flow inwards you have to give.
value is the actual value for the given patch. given by inletValue or patchface neighbour cell(zerogradient).
Hope this helps.
regards, Junwei
su_junwei is offline   Reply With Quote
Old   May 29, 2011, 22:43
Hossein
Thanks for your answer. It was useful for me.
Old   May 30, 2011, 13:28
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Junwei, your explanation about inletValue is clear for me but the one for value isn't.
Suppose you want a velocity pointing only outwards. It would be zeroGradient if velocity is outwards and (0 0 0) if it is inwards. I suppose inletValue should be (0 0 0) and it would represent the inlet velocity. Then what is the purpose of the "value" entry?.
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   May 30, 2011, 21:01
su_junwei's Avatar
su junwei
value is a keyword for all the numerical boundary condition. It is not used for input but calculated based on the boundary you set. It is useful for postprocessing. you can set the same value as inletValue, and it will be updated during the calculation.
sometimes, paraview don't like boundary condition without "value" entry.
Regards, Junwei
calim_cfd likes this.
Old   May 30, 2011, 21:42
Junwei, thanks for the clarification and confirmation. Tthat's true when values are calculated "value" entry data is replaced by which is calculated at running time.
Regards.
Research Scientist
Thread Tools
Trackbacks are On
