Home > Forums > OpenFOAM Running, Solving & CFD
adjust inlet temperature depending on values of monitor points (groovyBC)
Old   May 31, 2011, 03:30
Default adjust inlet temperature depending on values of monitor points (groovyBC)
Fabian Braennstroem
braennstroem is on a distinguished road
I would like to use an time-varying inlet temperature, where the temperature gets adjusted/controlled by the mean value of temperature probes and the mean value of a certain cellSet/faceSet (slice through the domain).
The adjustment should happen around every 500 iterations in small steps. If the mean values are above a certain limit, the inlet temperature should become smaller and vice versa.
Right now, I would say that the best approach would be to use groovyBC, where I could use as a variable:
Tmean{faceZone'sliceToMonitor}=average(T)
(Tmean>300.0) ? ((Tinlet=T{inlet}-0.5) : Tinlet=T{inlet}+0.5)
I think this could work...
Do you have an idea how to further include probes and how the time iterations of 500 could be achieved? Maybe it would be enough to slightly adjust the temperature after an initial convergence time with smaller steps continously.
Thanks!
Fabian
braennstroem is offline   Reply With Quote
Old   May 31, 2011, 04:50
Assistant Moderator
Bernhard Gschaider
Thanks!
Fabian
Hi Fabian!
The latest incarnation of swak4Foam (definitly in Mercurial, not sure about SVN) has something called "stored variables" which are variables that keep their value and which you can abuse to store states (of course you'll have to do some ?:-switching as all the variables are evaluated, but you'll figure that out). There is an example fillingTheDam-there. I'll give a more detailed explanation at my talk at the workshop, so if you're not already registered, its not to late ....
Bernhard
Old   May 31, 2011, 13:45
Fabian Braennstroem
Thanks... as always quite interesting!
The workshop is a bit too far away :-(
Fabian
Thread Tools
Trackbacks are On
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Temperature and shear stress depending viscositiy mannobot FLUENT 0 April 22, 2010 03:56
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
the material parameters depending on temperature Jason CFX 4 December 22, 2006 20:54
Problem with transport properties depending on Temperature galaad OpenFOAM Running, Solving & CFD 5 December 6, 2005 13:51
