-   -   rhoCentralFoam (http://www.cfd-online.com/Forums/openfoam-solving/89103-rhocentralfoam.html)
ramhari June 4, 2011 13:28
rhoCentralFoam
" 'rhoCentralFoam' is a transient/time accurate solver.
Then using higher Courant numbers (which is say under stability criterion) will help
in time marching to a steady state solution (SSS) which would be faster than the SSS reached using time accurate procedure."
(or) If it is not, any other alternate way to modify the code to reach the SSS faster!
I want anyone's suggestion/comment on this issue. :)
