Home > Forums > OpenFOAM Running, Solving & CFD
Which Solver should I choose?
Old   June 4, 2011, 13:51
Default Which Solver should I choose?
Mike
mikemech is on a distinguished road
I would like to simulate incompressible laminar flow over a semi-infinite flat plate at zero incidence, with constant density throughout the flowfield.
The thing is that I want to compare the results that I will get with OF, with a homemade algorithm that I have built in FORTRAN, that simply solves the Continuity and X-Momentum equations, like listed in the attachment.
I am thinking of choosing icoFoam or simpleFoam with turbulence turned off, but I can't understand how they are different (Transient vs Steady State solver) and what will the impact on my obtained solution be.
If anybody has a remark, I would be grateful
Mike
mikemech is offline   Reply With Quote
Old   June 4, 2011, 14:04
ramhari is on a distinguished road
If you are interested in steady state solution, u can opt for simpleFoam.
ramhari is offline   Reply With Quote
Old   June 4, 2011, 14:13
Mike
So, if I choose simpleFoam, what would be a reasonable value for timeStep in ControlDict? Should I set timeStep= 1 sec and run until convergence?
Old   June 4, 2011, 16:38
Alberto Passalacqua
Yes, and if you want 1D case, create a mesh with only one cell in the Y and Z direction.
Best,
Alberto Passalacqua
GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats.
Old   June 6, 2011, 17:09
Mike
Well, I want to increase Reynolds (~10^7) so that I have turbulent flow. I used k-epsilon model. I just introduced 2 files (k and epsilon) under 0 folder and the necessary fvschemes and fvsolution modifications. Is this correct? Or do I need other changes and files under 0 folder, like nutilda ?
And after that, how can I plot the u-velocity in gnuplot or paraview (if possible), towards timesteps ?
Thanks!
PS: i added 2 images. The first is the laminar fully developed boundary layer and the second is the turbulent fully developed boundary layer.
Old   December 13, 2011, 14:38
Ricardo
rvmedina20 is on a distinguished road
mikemech, Alberto....
why would one need to give a time step to this type of problem, when you are doing steady-state simulation??? if you have steady-state the time dependence would disappear wouldn't it??? Thanks
-Ricardo
Best,
rvmedina20 is offline   Reply With Quote
Old   December 14, 2011, 00:47
Alberto Passalacqua
-Ricardo
In steady-state solvers, the time-step is just a counter for the number of iterations. Simply use 1.
Alberto Passalacqua
Thread Tools
Trackbacks are On
A New Solver for Supersonic Combustion nakul OpenFOAM 6 March 30, 2014 03:00
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 11:34
Solver and geometry choose for drag coefficient calculation around circular cylinder at large Re lin OpenFOAM Running, Solving & CFD 3 April 16, 2009 10:50
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 14:08
can use coupled solver to calculate combustion cfdfans FLUENT 0 November 25, 2003 05:48
