fluctuation in force coefficients with dynamicTopoFvMesh
Old   May 1, 2018, 02:55
Default fluctuation in force coefficients with dynamicTopoFvMesh
sepehr_s is on a distinguished road
Hello
i want to simulate pitching and plunging airfoil with large amplitude in ground effect. because of large amplitude i use remeshing with dynamicTopoFvMesh.
first i simulate pitching and plunging airfoil out of ground effect. airfoil movement and remeshing is very good but when i active flow solver (pimpleDyMFoam), forces coeff (cl , cd) have fluctuations.
i solve this problem with dynamicFvMesh and compare result with kinsey and dumas, the results had very good agreement. then i simulate that problem with remeshing dynamicTopoFvMesh that results have fluctuation.
in both solver initial and boundary conditions are the same and flow solver is pimpleDyMFoam or icoDyMFoam with foam extend 3.1.
i examine different scheme, time step , ... but no effect on fluctuation.
what is the reason of this fluctuations?
how can i remove this fluctuation?
how can you help me please?
thanks.
sepehr_s is offline   Reply With Quote
Old   May 1, 2018, 17:10
Retired Super Moderator
Bruno Santos
Quick answers/questions:
  1. If you are running in parallel, try running a few iterations in serial mode instead. This is just so that you can put aside any influences that parallel decomposition may have on the flow field.
  2. If you are using PIMPLE, then try setting the "nOuterCorrectors" parameter in "fvSolution.PIMPLE" to a value larger than 2 or 3 - see this page for more details: https://openfoamwiki.net/index.php/O...hm_in_OpenFOAM - hopefully this will help stabilize the flow field after each mesh motion.
  3. Have you tried using Radial Basis Function (RBF) mesh deformation, instead of dynamicTopoFvMesh?
Old   May 2, 2018, 03:41
i ran the simulation in serial mode.
i set nOuterCorrectors up to 100 but after each remeshing of domain and remapping, the result show jumpping.
i didn't try RBF, because i must consider the ground effect and airfoils in tandem configurations.
thanks for rapid answer Bruno.
ActuatorDiskExplicitForce in OF2.1. Help be_inspired OpenFOAM Programming & Development 10 September 14, 2018 11:12
Sectional force coefficients tfuwa OpenFOAM Post-Processing 1 June 27, 2013 06:49
[OpenFOAM] spatial distribution of force coefficients in paraview&openfoam kkpal ParaView 1 April 21, 2013 07:15
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Density for calculating Force Coefficients ste_lakey CFX 2 September 19, 2005 04:35
