decomposePar failed in "field transfer"
Old   February 12, 2012, 14:28
Default decomposePar failed in "field transfer"
Aqua
aqua is on a distinguished road
Dear all,
I am trying to run a case in parallel, when run "decomposePar", it worked fine before "field transfer". no error, on warning, but just stopped..as follows:
Processor 15
Number of cells = 30270
Number of faces shared with processor 12 = 420
Number of faces shared with processor 14 = 1096
Number of faces shared with processor 8 = 343
Number of faces shared with processor 10 = 551
Number of processor patches = 4
Number of processor faces = 2410
Number of boundary faces = 8475
Number of processor faces = 10809
Max number of processor patches = 7
Max number of faces between processors = 2410
Processor 0: field transfer
Initializing the GGI interpolator between master/shadow patches: iminy/imaxy
Initializing the GGI interpolator between master/shadow patches: ominy/omaxy
it just stopped here, without finishing the decomposePar. The result is, in processor0/1/2/3/4/5... there is only the file "constant", but no file "0"..
Does anyone may help on this? what may be the problem?
Thank you so much!!
Aqua
aqua is offline   Reply With Quote
Old   February 12, 2012, 22:53
Abhishek
Abhishekd18 is on a distinguished road
That means you don't have the initial conditions folder named "0". If you are using different time for initial condition, try changing the start time in controlDict.
Abhishekd18 is offline   Reply With Quote
Old   February 14, 2012, 06:00
Aqua
Hello, Abhishek,
Thank you so much for your reply. Turned out that the mesh is not right. So current I am trying to modify the mesh...
Cheers!
Aqua
Transient boundary conditions Jarrod Sinclair (Sinclair) OpenFOAM Running, Solving & CFD 133 May 6, 2015 06:21
DeardorffDiffStress turbulence model Zuixy OpenFOAM Running, Solving & CFD 0 November 14, 2011 08:44
[OpenFOAM] ParaView/Parafoam error when making animation Disco_Caine ParaView 6 September 28, 2010 09:54
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
user defined function cfduser CFX 0 April 29, 2006 10:58
