Standard-k-€ vs. low-Re-k-€
I have a question about the difference in the calculation of the two different turbulence models Standard-k-€ (high-Re) and a low-Re model such as LaunderSharmak€. I think I have read that the high-Re model is proned to calculate turbulent eddies bigger than they are in reality. Alleged due to great values of viscosity. Because of that it is allegedly better to use a low-Re model such as LaunderSharmak€ to avoid this problem. I'm not sure if this is right, so if anyone knows something more about that please let me know. Best Regards, tH3f0rC3 |
hi,
low-Re models are used in wall bounded flows with resolved boundary layer since turbulent fluctuations and therefore the turbulent viscosity (leads to a low Reynolds number) are damped near walls. So when to use a low-Re model depends on your case. Different turbulence models normally have different scopes and it is your job to find the right one for your case ;) you can find some details in the Fröhlich BookLarge Eddy Simulation turbulenter Strömungen p. 52 gregor |
