May 17, 2011, 23:30 |
rhoPimpleFoam error
Hi Foamers,
I run a case for two inlet air with different temperatures in a channel. I set 0 directory as attached files. When I use rhoPimpleFoam as a solver I faced to this error: #0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: #3 Foam::compressible::RASModels::mutWallFunctionFvPa tchScalarField::calcMut() const in "/opt/openfoam171/lib/linuxGccDPOpt/libcompressibleRASModels.so" #4 Foam::compressible::RASModels::mutWallFunctionFvPa tchScalarField::updateCoeffs() in "/opt/openfoam171/lib/linuxGccDPOpt/libcompressibleRASModels.so" #5 Foam::fvPatchField<double>::evaluate(Foam::Pstream ::commsTypes) at /opt/openfoam171/src/finiteVolume/lnInclude/fvPatchField.C:222 #6 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::evaluate() at /opt/openfoam171/src/OpenFOAM/lnInclude/GeometricBoundaryField.C:306 #7 Foam::compressible::RASModels::kEpsilon::kEpsilon( Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libcompressibleRASModels.so" #8 Foam::compressible::RASModel::adddictionaryConstru ctorToTable<Foam::compressible::RASModels::kEpsilo n>::New(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libcompressibleRASModels.so" #9 Foam::compressible::RASModel::New(Foam::GeometricF ield<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libcompressibleRASModels.so" #10 Foam::compressible::turbulenceModel::addturbulence ModelConstructorToTable<Foam::compressible::RASMod el>::NewturbulenceModel(Foam::GeometricField<doubl e, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libcompressibleRASModels.so" #11 Foam::compressible::turbulenceModel::New(Foam::Geo metricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libcompressibleTurbulenceModel.so" #12 at /opt/openfoam171/applications/solvers/compressible/rhoPimpleFoam/createFields.H:57 #13 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6" #14 in "/opt/openfoam171/applications/bin/linuxGccDPOpt/rhoPimpleFoam" Floating point exception I guess the problem is about k-epsilon setting in 0 directory, but I don't know where is the problem. How can I remove this error? Regards, Hossein |
June 20, 2011, 07:04 |
Cecily
Rep Power: 14 |
Hi Hossein,
have you solve the problem? I have the same problem and can't find a solution. Greetings |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
c++ libraries and solver compiling | vaina74 | OpenFOAM Installation | 13 | February 3, 2012 17:43 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
