-   -   Foam IOStream error for InterDyMFoam parallel run - doesn't write uniform/time files. (http://www.cfd-online.com/Forums/openfoam-solving/90067-foam-iostream-error-interdymfoam-parallel-run-doesnt-write-uniform-time-files.html)
djpiro June 29, 2011 19:11
I am getting the following error while running InterDyMFoam on a cluster:
[6] --> FOAM FATAL IO ERROR:
[6] error in IOstream "/.../wedge10_3_2D_ultraFine_par_1.5_8/processor6/0.0132/uniform/time" for operation Ostream& operator<<(Ostream&, const char*)
[6]
[6] file: /.../wedge10_3_2D_ultraFine_par_1.5_8/processor6/0.0132/uniform/time at line 4.
[6]
[6] From function IOstream::check(const char*) const
[6] in file db/IOstreams/IOstreams/IOstream.C at line 93.
[6]
FOAM parallel run exiting
I have checked, and the uniform directory has been created for each processor at time 0.0132, but nothing has been written. I have tried this simulation multiple times, and each time it fails at the same time step with the same problem. Does anyone have any ideas as to what would cause this error?
Thanks,
Dominic
