August 1, 2011, 18:27 |
[solved]how to discretize fourth order term
Mieszko Młody
Rep Power: 17 |
Dear Foamers,
Does anyone of you know what is the best way to make 4 order term discretization: I mean: U(x,y) U_xxxx + U_yyyy Thanks ZM Last edited by ziemowitzima; August 4, 2011 at 12:27. Reason: solved |
August 2, 2011, 17:54 |
Mieszko Młody
Rep Power: 17 |
so far I found such explicit solution (U == T):
volVectorField gradT=fvc::grad(T); // (T_x, T_y) volScalarField Txxxx = gradT.component(0); // T_x gradT = fvc::grad(Txxxx); // (T_xx, T_xy) Txxxx = gradT.component(0); // T_xx gradT = fvc::grad(Txxxx); // (T_xxx, T_xxy) Txxxx = gradT.component(0); // T_xxx gradT = fvc::grad(Txxxx); // (T_xxxx, T_xxxy) Txxxx = gradT.component(0); // T_xxxx Maybe someone have some better idea ? Is it possible to descritize T_xxxx implicitly ? -ZM |
August 4, 2011, 12:26 |
Mieszko Młody
Rep Power: 17 |
seems to be solved:
http://www.cfd-online.com/Forums/ope...direction.html |
fourth order term |
Fourth Order Runge Kutta time integration | lr103476 | OpenFOAM Running, Solving & CFD | 45 | November 10, 2022 02:36 |
How to compute UDS fourth order gradient | Emma66 | FLUENT | 1 | April 27, 2010 05:44 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
Help for fourth order accurate convective schemes | Z.C.Wang | Main CFD Forum | 0 | January 15, 2009 06:53 |
Fourth order surface normal gradient interpolation | adona058 | OpenFOAM Running, Solving & CFD | 8 | September 24, 2007 15:12 |
