problem in ignition
Old   July 10, 2011, 11:06
Default problem in ignition
emad
rajabiemad is on a distinguished road
Dear all!
a implimented the ignition code for the cylindrical domain for non-premixed flame and used the reactingFoam
duration of ignition is 0.001 s and the diameter of igniton is 0.02
i get the following error :
FOAM FATAL ERROR:
[0] attempt to use janafThermo<equationOfState> out of temperature range 200 -> 5000; T = 5000.26
[0]
[0] From function janafThermo<equationOfState>::checkT(const scalar T) const
[0] in file /home/emad/OpenFOAM/OpenFOAM-1.7.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 63.
[0]
FOAM parallel run aborting
[0]
[0] #0 Foam::error:rintStack(Foam::Ostream&) in "/home/emad/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so"
[0] #1 Foam::error::abort() in "/home/emad/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so"
[0] #2 Foam::specieThermo<Foam::janafThermo<Foam:erfect Gas> >::H(double) const in "/home/emad/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libreactionThermophysicalModels.so"
[0] #3 Foam::ODEChemistryModel<Foam:siChemistryModel, Foam::sutherlandTransport<Foam::specieThermo<Foam: :janafThermo<Foam:erfectGas> > > >::solve(double, double) in "/home/emad/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libchemistryModel.so"
[0] #4
[0] in "/home/emad/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linux64GccDPOpt/reactingFoam"
[0] #5 __libc_start_main in "/lib/libc.so.6"
[0] #6
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
mpirun has exited due to process rank 0 with PID 7376 on
node emad exiting without calling "finalize". This may
have caused other processes in the application to be
terminated by signals sent by mpirun (as reported here).
please help me i want to remover this error
rajabiemad is offline   Reply With Quote
area does not match neighbour by ... % -- possible face ordering problem St.Pacholak OpenFOAM 10 February 7, 2024 21:50
conduction problem venkataramana OpenFOAM 3 December 1, 2013 07:30
Problem in implementing cht tilek CFX 3 May 8, 2011 08:39
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
