Visualization of rotor's induced flow
Old   November 9, 2011, 03:08
Default Visualization of rotor's induced flow
Jason Eason
JulytoNovember is on a distinguished road
Using MRFSimpleFoam, I've simulated the forces on a co-axial helicopter rotor system. However, I would like to view the airflow induced by the system. I'm working in 3D and using actual rotor data for the mesh using blockmesh. I've tried many things, nothing as worked for me. How can I view the the changes to the atmosphere caused by my rotor? Here is 2D picture of the rotor, just to give an idea of what it looks like. Keep in mind it is a 3D mesh. I lowered the quality of the mesh to decrease simulation time. Thank You.
Debian Squeeze - OpenFOAM-2.1.x, Paraview-3.12.0
JulytoNovember is offline   Reply With Quote
Old   April 23, 2012, 20:07
Jason Eason
I'm using pimpleDyMFoam, I changed to a single rotor for now. The rotor is in a cylinder with 2 inlets (top and bottom). Everything else runs fine just no induced flow. Could someone tell me what I'm doing wrong? The don't really understand the fvsolution and fvshemes, I taught myself OpenFOAM, so I'm still learning.
HTML Code:
|  \\    /   O peration     | Version:  2.0.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    rotor
        type            zeroGradient;
    top
    type        zeroGradient;
    bottom
    type        zeroGradient;
    wall
    type        fixedValue;
    value        uniform 0;
    insideSlider
    type ggi;
    value    uniform 0;
    outsideSlider
    type ggi;
    value    uniform 0;
    inlets
    type        zeroGradient;
HTML Code:
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0";
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    rotor
        type            movingRotatingWallVelocity;
    centre (0 0 0);
    rpm 450;
    axis (0 1 0);
        value           uniform (0 0 0);
    top
    type        inletOutlet;
    inletValue    uniform (0 -5 0);
    bottom
    type        inletOutlet;
    inletValue    uniform (0 5 0);
    wall
        type            fixedValue;
    insideSlider
    type ggi;
    outsideSlider
    type ggi;
    inlets
    type        pressureInletOutletVelocity;
HTML Code:
| \\      /  F ield         | OpenFOAM Extend Project: Open Source CFD        |
|  \\    /   O peration     | Version:  1.6-ext                               |
|   \\  /    A nd           | Web:      www.extend-project.de                 |
FoamFile
    version     2.0;
    format      binary;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    pcorr
        solver          PCG;
        preconditioner  DIC;
        tolerance       0.01;
        relTol          0;
    p
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-06;
        relTol          0.05;
    pFinal
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-06;
        relTol          0;
    U
        solver          PBiCG;
        preconditioner  DILU;
        tolerance       1e-05;
        relTol          0;
    UFinal
        solver          PBiCG;
        tolerance       1e-05;
        relTol          0;
PIMPLE
    nOuterCorrectors    2;
    nCorrectors         1;
    nNonOrthogonalCorrectors 0;
    pRefPoint        (0 0 0);
    pRefValue        0;
HTML Code:
FoamFile
    version     2.0;
    format      binary;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
    grad(p)         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      Gauss linear;
    div((nuEff*dev(grad(U).T()))) Gauss linear;
laplacianSchemes
    default         none;
    laplacian(nu,U) Gauss linear corrected;
    laplacian(rAU,pcorr) Gauss linear corrected;
    laplacian(rAU,p) Gauss linear corrected;
    laplacian(diffusivity,cellMotionU) Gauss linear uncorrected;
    laplacian(nuEff,U) Gauss linear uncorrected;
interpolationSchemes
    default         linear;
    interpolate(HbyA) linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    pcorr           ;
    p               ;
Visualization of Secondary Flow with ParaView idrama OpenFOAM 2 May 12, 2012 13:37
POINCARE SECTION- Visualization of Flow Structures Lu FLUENT 1 September 6, 2011 04:59
2-Phase flow visualization pranab_jha FLUENT 2 April 4, 2010 09:18
flow induced noise Maolin Tu Main CFD Forum 3 December 10, 1999 09:39
Question on 3D potential flow Adrin Gharakhani Main CFD Forum 13 June 21, 1999 05:18
