-   -   GAMG vs. PCG in fvSolution (http://www.cfd-online.com/Forums/openfoam-solving/90806-gamg-vs-pcg-fvsolution.html)
grandgo July 21, 2011 04:39
hi foamers,
i'm working with two domains of exactly same geometry and case configurations. one domain has 150000 cells, the other about 6*10^6 cells.
in the coarse domain case the GAMG solver needs about 30 iterations for one timestep (nCellsInCoarsestLevel = 1000). on the other hand, if i choose PCG the calculation needs 230 iterations.
in the fine domain case it's the opposite: PCG needs about 1000 iterations but GAMG does need more (maxIter limitation at 1500, various nCellsInCoarsestLevel).
what's your experience with GAMG? any tips what i could try?
best regards
grandgo
Antony_Bosco November 13, 2015 09:58
Did you find any answer?
I am solving a external flow simulation. When i increase the number of layers and decrease the min thickness close to 9.6e-06,in a GAMG solver the iterations reach close to 1000 and crashes but on the other hand PCG works very well.
Is there any reason behind.
Thanks,
Antony
