What is the significance of the input vectors (e1, e2, d, f) in porousSimpleFoam |
July 21, 2011, 13:28 |
Alex
I'm solving a flow through a radiator using porousSimpleFoam. I understand Darcy's law to the extent of what I read in wikipedia, but what is the coordinate system for and why does d and f have vectors associated with them?
July 22, 2011, 04:28 |
Dima Risch
The d f coefficients are relative to the porousZone and the resistance is described in each direction
so it is better to set the porousZone parallel to the e1 e2 plane to ease the entry for d and f that is what i have understood |
July 22, 2011, 06:54 |
#3 | |
Mark Olesen
Rep Power: 40 |
The d is darcy law and f is the Forchheimer coeff. If you have an isotropic porosity you can take any arbitrary local coordinate system (eg, take the global system) and use the same d/f coefficients for each direction. For convenience, you can set one coffecient direction and use a negative coefficient (eg, -1) as a multiplier for the other two directions. We often have porosities that only allow flow in one-direction. Our convention is to specify the coordinate system so that this is the local 'z' flow direction. |
July 22, 2011, 11:18 |
#4 | |
Alex
Here is the code taken from angleDuct tutorials in $FOAM_RUN/tutorials/incompressible/porousSimpleFoam Code:
1 ( radiator { coordinateSystem { e1 (0.70710678 0.70710678 0); e2 (1 0 0); } Darcy { d d [0 -2 0 0 0 0 0] (5e7 -1000 -1000); f f [0 -1 0 0 0 0 0] (0 0 0); } } ) |
July 22, 2011, 11:31 |
#5 | |
Mark Olesen
Rep Power: 40 |
You might then want to have 'e3' (ie, local z-direction) being the defined flow direction and add 'e1' (ie, local x-direction) to orient about this axis. |
cannot input CATIA *.model into gambit | soilinkin | FLUENT | 10 | January 12, 2011 00:47 |
Integration Points and normal area vectors | Bloshchitsyn Vladimir | CFX | 0 | November 26, 2007 07:35 |
2 velocity vectors | ashish | CFX | 3 | June 19, 2007 18:32 |
Velocity vectors | SA | Main CFD Forum | 1 | March 8, 2007 02:04 |
ANSYS ICEM CFD: lsdyna input file creation problem | Evan | CFX | 0 | June 15, 2006 13:12 |
