flowType – extensional flow and obtaining extensional stress |
July 26, 2021, 13:06 |
Sourav Mandal
Rep Power: 6 |
I can easily visualise the flowType in a nozzle geometry like in the attached figure 3. When I searched on this topic (extensional flow or extensional stress), there are important practical implications like in -
There is a functionObject called flowType that comes with both OpenFOAM-v2012 & OpenFOAM-8. The v8 provides the description: PHP Code:
The polymer mixing example used a software called BEMflow that provides the "particle flow number" in the range 0 to 1 (rotational, shear, elongation), through (probably) a particle tracking method. In contrast, OPenFOAM provides the flowType that ranges between -1 to +1 (rotational, simple shear, planar extensional). For my application (3D bio-printing i.e. flowing hydrogel with living cells through nozzles), it would be very nice to know what portion of the fluid is experiencing how much of stress (shear & extension). Now, my question is – Is there a way to decouple extensional stress and shear stress & quantify these two parameters individually in OpenFOAM? I'm not sure if this is the correct forum (maybe in programming & development?) but any kind of input would be very welcome |
elongation, extension, flowtype, shear stress, shearstress |
obtaining significantly different Flow profiles after only changing Mesh size | beratcagan | OpenFOAM Running, Solving & CFD | 5 | July 1, 2020 12:28 |
Gate valve flow simulations... | nikesh | FloEFD, FloWorks & FloTHERM | 5 | January 28, 2014 01:31 |
is there a post processing keyword for obtaining mass flow rate and total mass? | immortality | OpenFOAM Post-Processing | 29 | July 6, 2013 01:08 |
3D Mesh validation for obtaining wall shear stress | me03mao | FLUENT | 1 | February 16, 2006 05:42 |
