-   -   reactingParcelFilmFoam parallel (http://www.cfd-online.com/Forums/openfoam-solving/91023-reactingparcelfilmfoam-parallel.html)
A.Devesa July 28, 2011 02:49
Hello everybody,
could anyone please tell me, if the new solver reactingParcelFilmFoam (OF 2.0) can run in parallel. If yes, what do I need to do while decomposing? I tried several things, but I can't get a parallel simulation running with a surface film.
Thank you in advance!
Antoine
dima July 28, 2011 03:45
hi Antoine
the new solver reactingParcelFilmFoam can run in parallel
so take a look to the hotBoxes tutorial
there is a Allrun-parallel script using decomposePar for both, the wallFilmRegion and the primaryRegion
if necessary modify the decomposeParDicts and the Allrun-parallel script
hope this helps
HPC on the Lake April 12, 2012 09:08
The provided tutorial also crashes on my computer, caused by a segmentation fault. (see below, end of log.reactingParcelFilmFoam)
Other tutorials running in parallel are fine.
I installed OpenFoam 2.1.0, on Linux.
Anyone an idea where to check? Thanks!
Selecting composition model singlePhaseMixture
Selecting phase change model none
Selecting radiationModel none
Constructing surface film model
Selecting surfaceFilmModel thermoSingleLayer
[0] #0 Foam::error::printStack(Foam::Ostream&)[1] #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[0] #1 Foam::sigSegv::sigHandler(int) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[1] #1 Foam::sigSegv::sigHandler(int) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[0] #2 in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[1] #2 in "/lib/libc.so.6"
[1] #3 Foam::UOPstream::write(char) in "/lib/libc.so.6"
[0] #3 Foam::UOPstream::write(char) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[0] #4 Foam::UOPstream::write(int) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[1] #4 Foam::UOPstream::write(int) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[0] #5 Foam::operator<<(Foam::Ostream&, int) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[1] #5 Foam::operator<<(Foam::Ostream&, int) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[0] #6 in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[1] #6 Foam::Ostream& Foam::operator<< <int>(Foam::Ostream&, Foam::UList<int> const&)Foam::Ostream& Foam::operator<< <int>(Foam::Ostream&, Foam::UList<int> const&) in "/opt/openfoam210/platforms/linux64GccDPOpt/bin/reactingParcelFilmFoam"
[0] #7 Foam::processorPolyPatch::initUpdateMesh(Foam::Pst reamBuffers&) in "/opt/openfoam210/platforms/linux64GccDPOpt/bin/reactingParcelFilmFoam"
[1] #7 Foam::processorPolyPatch::initUpdateMesh(Foam::Pst reamBuffers&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[hnordbor-laptop:09290] *** Process received signal ***
[hnordbor-laptop:09290] Signal: Segmentation fault (11)
[hnordbor-laptop:09290] Signal code: (-6)
[hnordbor-laptop:09290] Failing at address: 0x3ea0000244a
[hnordbor-laptop:09290] [ 0] /lib/libc.so.6(+0x33af0) [0x7f08a166eaf0]
[hnordbor-laptop:09290] [ 1] /lib/libc.so.6(gsignal+0x35) [0x7f08a166ea75]
[hnordbor-laptop:09290] [ 2] /lib/libc.so.6(+0x33af0) [0x7f08a166eaf0]
[hnordbor-laptop:09290] [ 3] /opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam9UOPstream5writeEc+0x91) [0x7f08a255c711]
markusrehm April 13, 2012 04:06
I have similar issues but haven't investigated further. Does the error appear also with a tutorial?
Markus
HPC on the Lake April 13, 2012 05:12
It IS (!) a tutorial:
tutorials/lagrangian/reactingParcelFilmFoam/hotBoxes
I'm running OpenFOAM version 2.1.0.
dima April 13, 2012 05:29
Hi Roman,
do you run the ./Allrun-parallel skript unchaneged?
how many cores/processors do u use?
i do this tutorial with OF2.0.0
and today i try it with OF2.1.x
dima
HPC on the Lake April 13, 2012 07:11
Hi Dima,
Yes, I run the script unchanged. I run it on Linux/Ubuntu in a Virtual Machine on Windows 7 on a Laptop with 4 processors. I tried 2 and 4.
Roman
dima April 13, 2012 08:02
i tried it right now with 2 processors on openSuse
settings are in:
the Allrun-parallel script: runParallel $application 2
the system/decomposeParDict: numberOfSubdomains 2;
aswell the system/wallFilmRegion/decomposeParDict: numberOfSubdomains 2;
and it runs fine
    Selecting film injection models
        curvatureSeparation
        drippingInjection
Selecting distribution model RosinRammler
    Selecting film force models
        surfaceShear
        thermocapillary
        contactAngle
Selecting distribution model normal
    Selecting heatTransferModel mappedConvectiveHeatTransfer
    Selecting heatTransferModel constant
    Selecting phaseChangeModel standardPhaseChange
Courant Number mean: 0 max: 0
PIMPLE: Operating solver in PISO mode
Starting time loop
Film max Courant number: 0
deltaT = 0.0001436781609
Time = 0.000143678
Solving cloud reactingCloud1
Cloud: reactingCloud1
    Current number of parcels      = 0
    Current mass in system          = 0
    Linear momentum                = (0 0 0)
  |Linear momentum|                = 0
    Linear kinetic energy          = 0
    Rotational kinetic energy      = 0
    Total number of parcels added  = 0
    Total mass introduced          = 0
    Parcels absorbed into film      = 0
    New film detached parcels      = 0
    New film splash parcels        = 0
    Parcel fate (number, mass)
      - escape                      = 0, 0
      - stick                      = 0, 0
    Mass transfer phase change      = 0
Evolving thermoSingleLayer for region wallFilmRegion
diagonal:  Solving for deltaf*rhof, Initial residual = 0, Final residual = 0, No Iterations 0
smoothSolver:  Solving for Ufx, Initial residual = 0.9912919068, Final residual = 1.494629846e-17, No Iterations 1
smoothSolver:  Solving for Ufy, Initial residual = 0.9904653317, Final residual = 1.351398412e-17, No Iterations 1
smoothSolver:  Solving for Ufz, Initial residual = 0.9973363737, Final residual = 1.047149797e-17, No Iterations 1
smoothSolver:  Solving for hsf, Initial residual = 1, Final residual = 2.147073609e-19, No Iterations 1
smoothSolver:  Solving for deltaf, Initial residual = 0, Final residual = 0, No Iterations 0
Surface film: thermoSingleLayer
    added mass        = 0
    current mass      = 0
    min/max(mag(U))    = 0, 1.643271902e-21
    min/max(delta)    = 0, 0
    injected mass      = 0
    min/max(T)        = 350, 350
    mass phase change  = 0
    vapourisation rate = 0
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG:  Solving for Ux, Initial residual = 0.999999712, Final residual = 1.919568944e-06, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 0.9999997108, Final residual = 1.865176847e-06, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 1, Final residual = 3.672946737e-06, No Iterations 1
DILUPBiCG:  Solving for O2, Initial residual = 3.316429488e-05, Final residual = 1.064336272e-10, No Iterations 1
DILUPBiCG:  Solving for H2O, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG:  Solving for hs, Initial residual = 0.9999998726, Final residual = 2.498188599e-08, No Iterations 1
min/max(T) = 300, 350
GAMG:  Solving for p_rgh, Initial residual = 0.004945224294, Final residual = 0.0002832043458, No Iterations 2
time step continuity errors : sum local = 2.402975678e-08, global = -7.22322855e-11, cumulative = -7.22322855e-11
GAMG:  Solving for p_rgh, Initial residual = 0.0002832555659, Final residual = 5.552262167e-07, No Iterations 4
time step continuity errors : sum local = 4.689062126e-11, global = -1.044844441e-13, cumulative = -7.233676995e-11
DILUPBiCG:  Solving for epsilon, Initial residual = 2.208707685e-05, Final residual = 4.212265024e-11, No Iterations 1
DILUPBiCG:  Solving for k, Initial residual = 0.9999964134, Final residual = 1.87348777e-06, No Iterations 1
ExecutionTime = 22.55 s  ClockTime = 24 s
so it seems to be a virtual machine or maybe a OF-version problem
Dima
HPC on the Lake April 18, 2012 02:22
The problem is fixed in OpenFOAM version 2.1.x, i.e. when using the repository release. Simply download the repository release and build the code; it takes hours, unfortunately.
Thanks for working together!
